centre console no lights
Old Aug 19, 2023 | 11:04 AM
gabos's Avatar
c220 cdi 2.1
anyone had this issue everything works in the car apart from the lighting on my radio AC control unit and window buttons but they all function correct just at night cant see any of the buttons in complete darkness just the nav screen and cloak cluster lights up nothing else ive tried adjusting the lights with the little knob next to the wheel dont fix the problem car is 2012 220 cdi
Old Aug 19, 2023 | 11:32 AM
TimC300's Avatar
So they dont come on at night? if you set your headlights to auto do they come on at night, does the dash lighting change? Wonder if it may be a sensor that tells when its dark out. im just guessing. have you replaced or unhooked the battery lately to have the settings changed? Or it just started happening out of the blue?
Old Aug 19, 2023 | 05:06 PM
gabos's Avatar
c220 cdi 2.1
no dashlights come on at all only clocks and nav in any mode i put the light switch to but everything works just no back lights at night but i do have Auto Lights Inoperative on dash but even in manual mode it should light up the dash my battery was also dead a few week back
Old Aug 19, 2023 | 05:43 PM
TimC300's Avatar
So the lights in the switches are not turning on and you also have "auto lights inoperable" error message? Do your windshield wipers work? Your battery was dead, what did you do, jump it? is this when it all started after the dead battery? Like I said i have no idea, never happened to me. But a quick search for "auto lights inoperable" comes up with a few articles. One says to check all the fuses, especially the ones under the hood in the box on the drivers side. Another says they got the auto lights inoperable message after there alternator failed and they fixed it by replacing a module on the dash.
https://mbworld.org/forums/gl-class-...operative.html
