C250 CDI W204 2010 Cranking but not starting...
Old Sep 9, 2023 | 05:58 PM
Kickflip's Avatar
Mercedes C250 CDI W204
Angry C250 CDI W204 2010 Cranking but not starting...
Hi all
I have a lovely C250 CDI sat on my driveway, she's a 2010 W204 however its more of an ornament right now...
I have been away in a developing country for the last 8 months doing volunteer work and left the car with my parents whom made sure to start the car every month and let it run for half an hour or so.
The car ran and drove fine for a few days when I returned about a month ago, but I have since not driven it for about a month again. In that time I have given it an oil and filter change.
I went to start it and it yesterday and it just cranked over but nothing else. It also came up on the dash with a power steering fault message.
I charged the battery in case it was dead and tried again, this time no power steering message, however it still only cranked over and did not start.
I also used my OBD reader unto which it gave a DPF fault of P2436, and an engine RPM of 190 when cranking over.
I have checked the fuses and they seem to be fine.
I have checked the fuel pipes to and from the fuel filter and it feels as though they are stiffening up.
I have disconnected the battery and reconnected after an hour or so.
I have disconnected the DPF sensor.
Still it will not start...
If anyone has any idea as to what I can do next your help would be greatly appreciated!!
Old Sep 9, 2023 | 10:52 PM
TimC300's Avatar
have you tried pushing the gas pedal down while trying to start the car? A year ago i would get gas and then the car would not start, just crank over and over. I then pushed the gas pedal down and it started. This happened a few times. I ended up replacing the purge valve and the issue went away. i was also getting a check engine light, cant remember if the check engine light was on or came on when the car wouldnt start though.
When I search code P2436 im coming up with a secondary air injection issue. Maybe a relay, faulty pump, harness, or electrical connection according to that code. Im guessing.
Ill ad have you filled up with fresh gas lately? I ask because you mention the cars been sitting for 8 months.
Old Sep 10, 2023 | 01:15 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
2010 C250 CDI is an OM651 diesel. Fuel is stable during storage. Water accumulation could be an issue if the tank was not full, though.
6 Father's Day Gift Ideas Your AMG Loving Dad Will Cherish
Slideshow: Six Father's Day gift ideas your AMG loving dad will cherish.
By | 2026-06-03 16:34:48
