2009 C300 Front Sam Fusebox Part Numbers?
Old Oct 15, 2023 | 11:33 PM
porshapower's Avatar
1986 porsche 928 1997 sl 600
Hi, My "new" to me 2009 C300 has the driver side low beam headlight not working. I have removed the SAM and have a part number of A 204 900 67 09. I don't believe it was the original one as it has the jumper wire installed between 2 connectors and seems this single wire jumper connector is only used on a "replacement" Sam from what I saw on a Youtube video? I have been trying to find a list online using my vehicle identification number for Sam Part Numbers that interchange but no luck? Does anyone know where I can get this information without going to the dealership? My Vin is WDDGF54X69R045086. Thank you in advance for the help. My Best.
Old Oct 16, 2023 | 02:01 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
MB Online Parts catalog shows A 294 900 97 01 associated with your VIN if it is a petrol (gasoline) model. A 204 900 67 09 is listed for the 2008 C300.
https://www.mbonlineparts.com/oem-pa...t-204900670964
If you have a flex fuel model, re-enter your VIN and select “flex fuel.”
[I do not have a relationship with MB Online Parts]
Old Oct 16, 2023 | 02:31 AM
Hi. Thank you so much for the reply. I'll check tomorrow to see if it is Flex Fuel but yes it is gasoline. I went to the link you sent and the home page but can't find a place to enter the Vin? Only ask year,make,model? Thanks again for the help
Old Oct 16, 2023 | 09:22 AM
JettaRed's Avatar
Veteran: Army
Your car is Flex Fuel capable. Enter your VIN at www.lastvin.com
Old Oct 16, 2023 | 06:24 PM
TimC300's Avatar
Low beam is not working. What makes you think its the SAM?
Heres a diagram:
Heres a link to that page above. Theres too many part#s to list.
https://truckmall.ru/epc.aspx?mid=10519&subcatid=2942
Old Oct 16, 2023 | 08:53 PM
[QUOTE=JettaRed;8861916]
Thank you so much for clearing that up for me. The hunt for a SAM begins Thanks Again.
Old Oct 16, 2023 | 09:08 PM
Heres a diagram:
Thank you for the reply. I ran the codes and there was code for low beam short to ground SAM. Thanks again for the help.
