Wheel Speed Sensor 2013
Voltage of control unit N30/4 (Electronic Stability Program Control Unit) is too low (under voltage)
Implausable Values of Sensors on front axle
Not sure what to do next. I am using an iCarsoft EU Pro for diagnostic. Thanks in advance for any suggestions
Have you checked the brake fluid level just for fun?
I was reading some other posts where people had this issue and they swapped the sensor but ABS light remained on. They were able to read speed and forward motion from that sensor though. They say the solution was a new wheel bearing, in there Mercedes the magnetic ring is in the wheel bearing, not in the seal like in a W204. On the W204 I think its on the axle part of the seal.
i had that code previously and nothing came of it. I remember driving and the ABS light started flashing on and off. has been fine since.
