Errors can someone help
Old Nov 8, 2023 | 02:18 PM
meler-andy's Avatar
w204 merc 2011
P004500
P004500 : The charge pressure control valve has an electrical fault or interruption. / -The charge pressure control valve has an electrical fault or interruption. / The boost pressure control flap has an electrical fault or open circuit.
criticalLast occurrence:
P013326
P013326 : Oxygen sensor 1 (cylinder bank 1) has a delayed reaction. The signal change rate is below the permissible limit value. / -Oxygen sensor 1 (cylinder bank 1) has a delayed reaction. The signal change rate is below the permissible limit value. / Lambda sensor 1 (cylinder bank 1) responds with a delay. The signal change rate is below the permissible limit.
IC - Instrument cluster(A1)
B210B85
B210B85 The power supply in the system is too high. There is a signal above the permissible limit value. - STORED
moderateLast occurrence:
AAC - Air conditioning(N22/7)
B10B387
90B387 - Electric heater booster 1 has a malfunction. The message is missing.
B119100
919100 - The current refrigerant level is outside the permissible range.
Driver-side SAM - Front signal acquisition and actuation module
B237971
B237971 : The wiper motor has a malfunction. The actuator is blocked. / -The wiper motor has a malfunction. The actuator is blocked. / - The wiper motor has a malfunction. The actuator is blocked.
Rear SAM - Rear signal acquisition and actuation module
B170715
B170715 - The output for the left backup lamp a malfunction. There is a short circuit to positive or an open circuit.
DCM-LR - Left rear door(N69/3)
B190915
990915 - The output for actuator motor 'Additional door lock' has a malfunction. The output for the mirror heater has a malfunction.
WBS - Hazard warning switch
B237971
B237971 The wiper motor has a malfunction. The actuator is blocked.
RevETR-LF - Left front reversible emergency tensioning retractor(A76)
C130555
C130555 Generic communication fault code - STORED - STORED
RevETR-RF - Right front reversible emergency tensioning retractor(A76/1)
C130555
Old Nov 8, 2023 | 05:24 PM
JettaRed's Avatar
Veteran: Army
Have you recently had to change your battery or get a jump start? These may all be battery related.
Old Nov 9, 2023 | 01:07 AM
meler-andy's Avatar
w204 merc 2011
battery has been changed like year ago ,but had problems with a starter
Old Nov 9, 2023 | 01:24 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Have you tried clearing the codes to see which ones come back? If all or most return, consider a trouble code storm. Two possibilities are a CANBUS problem and a faulty module pulling the CANBUS performance down so the ECU interprets errors. View real time streams to see if one of the failures is occupying most of the available band width. It is unlikely that many unrelated codes occur at the same time.
Old Nov 9, 2023 | 05:02 AM
meler-andy's Avatar
w204 merc 2011
i will do but just wanted to keep them for now incase its code storm man ,and something go wrong , i know there is small electrical foults like reverse light ,cos the cable has melt litle bit so i tried to fix it and clean the connector ,then left indicator works sometimes ,sometimes not ,, yea need to sort this car properly out
