Front Right SRS Intermittent Warning - Unplugging Yellow SRS Connector Under Seat?
Been having this small issue since March, not a huge deal really if I'm the only one driving, so I've ignored it. But if there is a passenger in the passenger seat, often times, I will get a dash warning for the front right SRS. This popped up out of nowhere a few weeks after getting the car (used), but I know the airbags still work because the light in the middle of the center air vents does not light up to indicate the airbags are disabled, whenever I have a passenger that is.
I suspect that it's a simple connection problem from the seat position being moved around. I'm thinking of unplugging the main yellow connector under the seat and plugging it back in to ensure a tight connection. Would I need to disconnect the battery first before doing this? Or is unplugging while the car is off enough?
Would appreciate any advice, thanks!
