Hard shifts on a cold engine
- How did your mechanic check the tranny fluid level? The only way is to open the drain plug at a SPECIFIC TEMPERATURE and see if the fluid drips out. Too cold or too hot will give an incorrect reading.
- How cold is cold? Dubai cold or Anchorage cold?
- When did this start?
- When was your last transmission service?
I had it serviced in December before a road trip. The hard shifts started when I got back. I took it to a transmission specialist, they took it for a drive, found the fluid to be low and filled it up. I don’t think they checked the temp. When it continued, I took it to a mechanic, they checked it (without checking the temp) and said it was nothing. Cold just means it’s been sitting overnight. The temp outside is roughly 30C or 80F. What temp should it be when I check it?
- Who serviced the tranny? Mercedes or an indy?
- Was the transmission specialist a Mercedes transmission specialist?
- What fluid did they use to "top it off". It needs to meet the exact Mercedes specification for your transmission build, either identified as ATF-134 or ATF-134FE. They are NOT interchangeable nor compatible.
Here's an important link: https://bevo.mercedes-benz.com/index.php?language_id=1
