Rusty ground wire to rear lights block
Managed to carefully clean and press contacts together and it works (for how long it remains to be seen).
After reading a while about it, it seems like a very common issue for W204. In some countries it was considered a recall. Opened my other rear block - the ground wire is in same condition.
Whats the best way to deal with it? I have ordered new plugs with a proper thickness wire so thinking replacing original ground wire all the way (if it is doable without dismantling half of car - not sure how long it is) or at least the part coming into the plug, while soldering it to debris of old original ground wire.
Im not sure what the "block" is, and you write that the ground wire is completely rusty and half melted. The entire wire? photos would be helpful.
I would just remove and replace the damaged parts. if its just a rusted connector inside the harness then remove that connector and crime on a new one and put it back in the harness. if you need to remove some wire just cut it and add some new wire so its the right length again. I like to solder all my wires then cover with heat shrink
Below is for 08-11.
4 bucks per pin is a rip-off but no seems like no choice. Will ask local dealer with part numbers - thank you
The connector at the Mercedes dealer near me is $4.20 each. Or search online for "Molex Female Connector" and see if you can find the right size, I dont know the specific size so not any help. Or ebay has a few options.
Here's the post I made about it with photos and part #'s. https://mbworld.org/forums/c-class-w...ar-window.html
