Srs system malfunction
Old Mar 17, 2024 | 07:24 PM
user 70280492444's Avatar
Recently took out both my driver and front passenger seat without disconnecting the battery first resulting in airbag codes showing up. Am I able to clear codes or do I have to check for anything.
Old Mar 18, 2024 | 01:38 AM
cvx5832's Avatar
325Ci, 325Cic, C300
Reconnect and clear it
Old Mar 18, 2024 | 05:36 AM
JettaRed's Avatar
Veteran: Army
Disconnect your battery before reconnecting your seats. If you already reconnected, clear the codes—they are STORED and not current.
Old Mar 18, 2024 | 08:00 PM
if they code description says Stored am I able to just go and clear all codes that say it’s STORED and not not current? And they should all still work fine such as this one
Old Mar 18, 2024 | 08:07 PM
JettaRed's Avatar
Veteran: Army
If they are STORED and not CURRENT, then clearing them should not be a problem. These cars are very temperamental when it comes to voltage levels. That code could be caused by disconnecting your airbags or something else. If it was still a problem, it would show as CURRENT and STORED.
