Flex Fuel Wiring
Does anyone with a flex fuel capable C300 know where the wiring for the fuel quality sensor traces to? I think it goes to the front SAM, but I'm not sure.
I'm trying to get together everything to swap in the fuel quality sensor to my GLK so I can run E85, but none of my diagrams show the wiring for the sensor.
I was about to caution you because I had a SA spec 3.2L W211 that was certified for E90 and literally nothing in the fuel system was the same: fuel pump, injectors, ECU program. It also had less HP.
The sensor is located on my C-Class midway on the chassis on the driver side.
