air tube 2013 C250
air tube 2013 C250
This is what I found after taking out all the tape holding this together from the previous owner.
This is fit snuggly does it still need a clamp or a zip tie will do?
![](https://cimg9.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_5129_d0a81783d9c63ccc322c7924df073f908dd5ea65.jpeg)
![](https://cimg1.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_5128_7a568eed55275798b461db518c81228bd7770c36.jpeg)
![](https://cimg2.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_5132_48c569f47dfb6b950121bc38066ec3182a30bd09.jpeg)
![](https://cimg3.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_5134_a5067d93fbaa3f11b0ce268a534283841717c018.jpeg)
![](https://cimg5.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_5137_627343c31d4df7d511d719ae5555d095534efac7.jpeg)
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_5138_c1cf2c9248392190d0b120547e5e9a8a3dc325af.jpeg)
![](https://cimg8.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_5140_478ac2ee2310e51222ac36051f9321fa80cccd24.jpeg)
antboii (04-07-2024)
I tried to use the spring clamps but they were so hard to align and install so I will just use a regular worm gear type clamp
antboii (04-08-2024)
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Received 1,602 Likes
I don't think that's an air tube. Looks like a coolant hose. I also don't think the fusing tape is a good long-term solution.
I do not know if a misfire could be caused by this tube leaking could be since the intake air volume is measured by the MAF sensor. After I replaced that hose the car runs smoother and was no longer sluggish and then leading to a misfire. Anyway we shall see if the misfire does not come back.
