Delay in Gearbox Engagement
I have started to experience a slight issue with my automatic gearbox engagement. If I slow down for instance in drive mode, then start to accelerate there is a delay and then a sudden engagement and thrust.
I have had a recent transmission service done at Mercedes.
Your thoughts to the problem and any ideas how to resolve the issue would be appreciated.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Received 1,775 Likes
Does this happen all the time or occasionally? How long ago was the transmission service?
What do you mean by "drive mode"? Is that C or E, and not S?
Is the engine hesitating or the trans? Does it feel like the trans drops a gear then goes?
When was the last time the engine had a tune up?
I would start by scanning the car and check for any codes/faults.
You can try resetting the transmission. i read it can make the car relearn your driving habits. I have personally never done it. : https://www.mercedesmedic.com/reset-...-instructions/
Looks pretty simple to do:
- Turn the key to ON. Do NOT start the car.
- Press gas pedal to the floor for at least 10 seconds.
- After at least 10 seconds turn key to off position. Gas pedal still pressed to floor.
- Release gas pedal. Wait a few minutes.
- Drive the car.
- Drive the car.
Transmission learned values can also be reset using XENTRY. That is not the same as the process to teach-in, which is a bit complicated, but rather it resets the transmission to factory settings. I did it once on my 2004 SL500 with a 1st generation 7G and shifting was rough for a short while, but smoothed out after driving a bit.
I do not know if this can only be done with XENTRY. I have not looked if LAUNCH can do it.
Hi, this issue seems to happen to my 2013 C250 as well, and I also get a P0705 code when I use my scanner. The car feels sluggish or even jumpy getting up to speed from 0-35 mph, and when slowing down, it feels like you're being pulled back from the transmission dropping a gear and continuing. Slowing down and then accelerating within a short moment also causes a delay in shifting. My car has 99k miles, so it may be a case of a transmission service being much overdue. The code points to a TCM range sensor issue, but hopefully it's nothing too serious.
