Power steering reservoir crack
Old May 14, 2024 | 02:01 PM
jasejason's Avatar
mercedes c class 220D
I recently found a crack in the power steering reservoir where one of the hoses connect causing the fluid to leak. I had the pump including reservoir replaced and less than 100 miles later the reservoir cracked in the exact same place.
can anyone suggest what might be causing this?
Old May 14, 2024 | 03:14 PM
TimC300's Avatar
Would have to see what the crack looks like to give an opinion. I dont see a new reservoir cracking that easy.
Old May 14, 2024 | 03:20 PM
jasejason's Avatar
I can’t get a photo but essentially the crack is right on the join here both times
Old May 14, 2024 | 04:16 PM
cvx5832's Avatar
325Ci, 325Cic, C300
If your mounts are shot, you'll have excessive movement in that area where you have the hose tugging at that outlet with every push or release of the gas pedal.
Old May 14, 2024 | 05:45 PM
TimC300's Avatar
Worn engine mounts makes sense. have someone rev the engine while your watching that hose and see if it gets tight at that connection.
Old May 15, 2024 | 08:41 AM
Thguns's Avatar
2009 Mercedes C63 AMG, 2013 Mercedes C350 4Matic Coupe. 2012 GLK 350 4Matic
Motor mounts
put the selector in drive foot on brake and slowly torque the engine and observe engine movement, can also do this in reverse. Don’t stand in front of vehicle. This is called engine brake torque, but you need to know what you are doing.
Old May 15, 2024 | 12:10 PM
cvx5832's Avatar
325Ci, 325Cic, C300
With the higher torque inherent in diesels, it's not hard to imagine mounts that have long since died.
How many miles on the car?
