Can I straight swap Halogen H. Lamps for Bi-Xenon ones?
Old Aug 5, 2024 | 04:00 PM
DrManhatta's Avatar
W204 Mercedes C- Class AMG Sport
I currently have standard Halogen headlamps and bulbs fitted in my W204 AMG Sport. However, I much prefer the look of the Xenon headlamps with the side marker LEDs and the cleaner blue/white colour they give off.
I've checked the wiring for my headlamps and the Xenon ones and the only difference is the plug on my car has 1 less pin than the Xenon plug (which is the Canbus wire I believe) and obviously my car is not fitted with an ECU that can receive a signal from this canbus wire, so presumably it wouldn't result in any messages being displayed in the instrument cluster?
Am I right in thinking the Xenon headlights should then be plug and play?
Thanks in advance
Old Aug 14, 2024 | 02:56 PM
Widebodycoupe's Avatar
C250 2012 coupe
Yes you can however the wires for the ballast will not fit inside the light housing. What I did was slice the rubber to pass the wires through. It might be a cap (i hid all my cars) and if so I cut a pie slice out of the cap so wires will pass through. Then just self tap the ballast somewhere close by where they won't get wet.
The problem with the cap/cover having a cut in it is they lights could fog up inside now. I use silicone to try and seal it more. Or go the opposite route and open up more holes so it will breathe and the fog will dissipate quickly.
