What is this AC / vent sound? (2010 c300)
The AC is working, so don't know if it's a refrigerant issue
It's. 2010 c300
When the ac is running do you see water dripping down onto the ground from somewhere?
Have you had any work done to the car lately, anything?
Was this while the engine running ac on?
Was it after running and you just turned it off?
More specific info like that because the car behaves different thru instances like weather is been running or not and weather or not you open the door or not. So get specific and maybe we can give a good guess what it actually is.
could a blocked drain hose cause the sound? I'll have a poke around and see if I can snake something up the drain hose this weekend
This sound has been happening for a year or more, so no recent work caused it
Yes only when the engine and AC are on does the sound happen
Then it's just my 2cents but I would pull the two covers that are above where your feet sit to expose the undersides of the dash and put a coke electric fans blowing air up there fire a day or so.
Water issues are a huge problem to diagnose and repair.
