2012 OM651 vibrations when A/C is on
Old Aug 13, 2024 | 07:25 AM
Entyy's Avatar
Mercedes W204
Hey guys, a while ago I changed the gaskets for my oil cooler, valve cover and every other "small" part that needed to be removed to access those. As you know it's a lot of work till you do it as lots of parts are in the way. The problem is, after that when I now turn the A/C on the car starts vibrating hard, especially while idling(in small intervals and you can feel it everywhere - in your feet, shifter, etc), which leads me to the thought that something gets extra load and can't handle it. The mechanic that did the job said that they haven't removed the A/C compressor in order to access the other parts, so I it *should* be coming from somewhere else but I have no idea where. Wanted to check if anyone has dealt with a similar problem/ has any ideas so I can try fixing it myself before bringing it back to the shop as it's in another city and will take me a lot of time/resources. Thanks! The car is C220 diesel, 170hp, OM651, 2012
