Error codes, P0106, U0120, jumps at idle (sometimes) ?
It happens random. Sometimes often, sometimes good for a long time. Warm or cold. Not really sure where to start to look? Spark plugs? Map sensor? Ignotion coils?
Today the fault lamp lighted up. First time while the problem have been going on for weeks.
Even harder to check as it happens just sometimes.... It's my first MB so totally lost where to start =)
Anyone have any advices?
Here is the scanner report.
Thanks in advance.
DTC report
Connection profile: Mercedes-Benz OBD-II / EOBD + AT (CAN)Date: 11/15/2024 6:41:58 PM
OBD-IIOBD-II
DTCs: 3
P0106 [0x0106]
Manifold absolute pressure (MAP) sensor/barometric pressure (BARO) sensor - range/performance problem
Status: Confirmed
U0120(87) [0xC12087]
Lost communication with starter/generator control module
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
P0106(64) [0x010664]
Status: Confirmed, Test failed since last DTC clear, Warning indicator requested
Engine control unitEngine control unit
DTCs: 2
