clunk in rear delayed reverse to drive
Checked the driveshaft it seems solid.
Transmission bushing looks ok but could be perished.
It feels like worn out differential bushings.
Any common faults on this chassis that show up as this clunk?
Transmission shifts like butter on upshifts when loaded
All drivetrain fluids are fresh.
133K
2008 C300
Well following up on this. It does appear it was clearing the adaptations. Had them cleared again and then drove slowly for about 15 miles.
No more clunking. There is a very slight flare going into fourth only. No other gears do this. Fourth does about a 100-150RPM flare. It hopefully will go away over time. Now when providing a little more throttle it does not flare.
IIRC the adaptation process for 5G-Tronic without Star Diagnostics is:
Set transmission mode selector to “S.”
Drive slowly accelerating through all gears not allowing RPM to go above 2400.
Coast to a stop not breaking until transmission downshifts to 1st.
Let engine idle for 10 minutes.
Repeat 3 more times.
Shut off engine, exit car and lock doors.
That resets basic solenoid fill routines and puts conductor plate back in normal adapt mode.
Get back in and check upshifts and downshifts in regular driving modes including “C” for 2nd gear start. Check reverse for smooth engagement. Drive in an area that will allow checking throttle downshifts. 5-4, 4-3, and 5-3 should be sufficient. Stop car, shut off engine, lock doors.
It’s not part of the routine, but I always used to check WOT downshift from about 20-25 mph where I could do it safely.
The 5-4 and 4-3 downshifts should allow the TCU to adapt that 3-4 flare out unless there is an actual problem.
If issues arise, repost and I’ll get out a hydraulic circuit diagram and we’ll see if we can resolve it. All my 722.6s went well past 130k miles and were still flawless when we retired the vehicles.
