CV Axle Bolt Help!
Old Dec 20, 2024 | 09:23 PM
Arlmeroc18's Avatar
2014 C300
CV Axle Bolt Help!
CV axle bolt won't come off or loosen
, I have tried propane torch, and pb blaster. Any other ides?
Old Dec 20, 2024 | 11:41 PM
TimC300's Avatar
I would put the wheel back on with the center cap removed, lower the car then use a long piece of pipe over my breaker bar to crack the bolt off.
Old Dec 21, 2024 | 12:28 AM
TimC300's Avatar
That bolt looks to be in great condition. I just got done spraying fluid film and surface shield all under mine to help with rust prevention. I sprayed the axle bolts in case I ever need to get them off.
I cleaned the rims while I had them off so removed the center caps and snapped off one of the tabs. Probably because its cold out. Used some super glue then alot of hot glue to put the tab back on. Actually worked and it went back on without breakibng again. ordered 4 more anyways.
Old Dec 21, 2024 | 03:00 PM
RobertR728's Avatar
2014 c300 w204.080 3.5 v6
Like mentioned put the wheel on then try with a large breaker bar or a good impact wrench.
Or you can have someone out they foot in the brakes and do the same thing.
