Take your key from ignition(ESL was changed)
Old Jan 6, 2025 | 09:36 PM
--mb--'s Avatar
Mercedes-Benz W204, C250, year 2011, Canada.
Hi,
I keep getting this annoying message on my dashboard: "Take your key from ignition."
After reading a bunch of threads, I figured it might be the ESL lock motor. But the thing is, the dealer already replaced the ESL lock at 43K miles (I’m at 52K now).
Any idea what else it could be?
Old Jan 7, 2025 | 11:46 AM
JettaRed's Avatar
Veteran: Army
please provide your year and model and location.
Old Jan 7, 2025 | 12:07 PM
--mb--'s Avatar
Oops, sorry here is the info:
Canada, Quebec, C250 4Matic, 2011.\
Thank you!
Old Jan 7, 2025 | 03:18 PM
TimC300's Avatar
When does this message show, is the key in the ignition and you are driving? Or after you stop the car and take the key out?
Old Jan 7, 2025 | 03:24 PM
--mb--'s Avatar
When I insert the key, the message appears. But as soon as I turn the key to start the engine, it goes away and never shows up until I insert it back again.
Another strange thing I noticed is that if I insert the key while sitting in the passenger seat, the message doesn’t show up at all.
Old Jan 7, 2025 | 08:06 PM
Demvang's Avatar
2011 C300 4Matic Sport
It’s normal, a reminder that’s all. Put the key in from the passenger’s side, the sensor cannot detect someone sitting behind the steering wheel, so there’s no reminder.
Old Jan 7, 2025 | 08:10 PM
alynch's Avatar
2020 C300, 2013 C250, 2000 Boxster S
Normal operation. The vehicle senses when the engine is off, the key is in the ignition, and someone is sitting in the driver's seat. The message is displayed to remove the key from the ignition (as it expects you to exit the vehicle). The message is not displayed when you are sitting in the passenger seat since this is not the driver's seat.
If the message is popping up randomly, the culprit could be an intermittent driver's seat sensor or the sensor that the key is in the ignition.
Old Jan 7, 2025 | 08:46 PM
TimC300's Avatar
I have never seen that message pop up on mine. But im not familiar with Canadian models, I know there are some differences from reading the operators manual, it will state something like "Canada models only". Look in your operators manual. Mine says to just remove the key.
id say there was something wrong if the car wouldnt start. But if there is nothing wrong its probably normal.
Old Jan 7, 2025 | 10:28 PM
--mb--'s Avatar
I hope it’s just a reminder. However, I’d expect this kind of reminder to pop up after I switch off the engine, not before I start it if it wants to remind me to not forget the key in the car.
Same thing in mine, just remove the key.
Old Jan 8, 2025 | 03:50 AM
RobertR728's Avatar
2014 c300 w204.080 3.5 v6
I only get the remove your key message if the key is in with the door open on my 2014 c300
Old Jan 8, 2025 | 07:06 AM
--mb--'s Avatar
Wow, that’s exactly it! I just realized that I was doing all these tests with the door open. And that also explains why the message doesn’t appear when I’m sitting in the passenger seat—because at that moment, the driver’s side door is closed.
Huge thanks to everyone! I think the system is working as it should.
Old Jan 9, 2025 | 07:30 AM
RobertR728's Avatar
Glad it was a easy fix 😁
