My car is vibrating whenever I cruise and try to pick up speed
Old Jan 13, 2025 | 03:21 PM
Amralkurdic300's Avatar
I need help figuring out what’s wrong with my car this has been killing me ever since I bought it. For example say I’m getting on the highway I hit 60mph but I have to let go off the gas cause of the person in front of me then whenever I try and reengage with the gas pedal again the car starts vibrating unless I slam the gas the car won’t stop vibrating. And this happens whenever I’m cruising also going uphill it vibrates a lot when accelerating. I changed sparks,coils, and intake manifold. My next move is going to be a tranny fluid change. Has anyone had this problem before. And this only
happens when I take a turn and try to accelerate or going up hill accelerating, orrrr when I am at cruising speeds trying to pick back up let’s say from 50-60 mph.
File Type: mov
Old Jan 13, 2025 | 04:05 PM
RobertR728's Avatar
2014 c300 w204.080 3.5 v6
Sounds like three transmission slipping to me. You can try a lower gear and see if it vibrates also try too put in neutral thru the range you know it vibrates see if there vibration goes away.
Old Jan 13, 2025 | 04:16 PM
the transmission shifts pretty good tho. And it does it only at 2rpms
Old Jan 13, 2025 | 04:41 PM
also if I slam the gas the car shifts and drives smooth so that’s why I’m not thinking it’s a bad tranny. Can bad or low tranny fluid cause this problem? Because I’m getting new fluids this werkend
Old Jan 14, 2025 | 01:39 AM
RobertR728's Avatar
Sounds like to meet that when you are at low load cruise speeds when the transmission is most likely in high gear and torque converter locked. I would say either the converter is slipping or overdrive use slipping. When you smash the gas there car will unlock the torque converter and downshift out of overdrive to give you more torque and power.
Those symptoms usually show up as a chatter/shudder of the car at cruise speeds that goes away when shifting into neutral or speeding up quickly
Old Jan 14, 2025 | 07:15 AM
could a tranny flush and new fluid fix the problem maybe? Because the car only has 60k miles no way the torque converter went bad
