NO CRANK NO START
Old Jan 22, 2025 | 07:42 PM
kasey007's Avatar
NO CRANK NO START
So today, I went to the store before work to get breakfast, and came home. Everything worked fine. I shut the car off, went inside for 45 minutes, came outside to crank it up and leave… the mileage on the dash shows up, the bell chimes and the interior lights come on, yet the radio remains dark. When I try to turn it all the way over literally NOTHING happens no whirs form the motor, no starter cranking nothing. The battery has 12.5V and I have a brand new backup I tried just in case. Any ideas would be appreciated !
Old Jan 23, 2025 | 02:29 PM
hmclaughlin67's Avatar
2008 C300 4Matic
Do all the lights on the dash come on? The first place to check is the starter. When you try to turn it over, do you hear the “click” from the starter solenoid? Or is it completely silent?
Another fairly common thing is the shift linkage can get stuck. Try shifting out of park into neutral, and then firmly put it into park again. See if that makes a difference.
Old Jan 23, 2025 | 02:59 PM
SnoopLevine's Avatar
'18 E63S Sedan - PA1 'Orange Pearl Metallic'
Possible EIS/ESL failure. Unfortunately very common on W204, worth looking into further to determine if that's the culprit.
Almost certainly the issue if you are not hearing the typical 'click' sound when inserting your key fob. Here's a video of the noise for reference: https://www.facebook.com/watch/?v=402187247689005
Old Jan 29, 2025 | 12:22 AM
elpasotuner's Avatar
Veteran: Army
2012 MB C250
Same issue here!
Unfortunately, my car’s ESL locked so i removed it myself (Oct ‘24), since then i’ve manually started my car by the starter fuse, but eventually 2 wks ago it completely died, to include draining all power from my battery, i didn’t hear any clicks from my starter, & worth mentioning my car constantly leaked oil. I just replaced my old starter motor today but i have to juice my battery before i try again, i’m doubtful i fixed my troubles tbh. I’ve researched there’s plenty of culprits to cause for a “no crank” to a W204, i.e. oil leaks, fuse, electrical, alternator, just to name a few *sigh. So i hope this helps, pls lmk if you share my troubles; i’ll follow your thread. Good luck!
Old Jan 29, 2025 | 07:14 AM
2008 C300 4Matic
If you tried to jump your car and you got sufficient power, it won’t be the alternator. Oil leaks also won’t directly cause your engine to not start, and especially won’t cause it to not crank. However, oil leaks can kill your starter super fast, so I suspect that may have been your problem. You also should check the fuse you’ve been using to start the car with to see if it’s blown.
While what you’re doing does work to bypass the ESL, I strongly recommend you actually take the time to replace the system, or at least bypass it with an actual kit rather than jumping the car. That’s meant to be used maybe once strictly to drive it to somewhere it can be fixed, and that’s it.
