Brake Replacement
Brand new to this site. Appreciate in advance everyones feedback and guidance. I have a 2015 C400 55kmiles. I need front brakes and I'm looking to change myself. Just wondering if there is a way to tell ahead of dismantling everything if I would need to change the rotors as well. Would love to save some time/money and simply change the pads only but looking for guidance..
Thanks all!
The max and min thickness should be stamped right on the hub part of the rotors when you remove the wheel. If you can feel a lip on the rotor then chances are its worn and should be replaced. Remember if you just replace the pads the old rotor will be on the car along time, dont want it going down below the minimum before the pads wear.
I found a useful sheet from MB showing what exactly should be greased and what should NOT be greased. I have been following it since i replaced the brakes over 5yrs ago and have had no issues with them.
Ill post an example of the brake rotor thickness specs. Im not sure your exact submodel.
Not sure your location. When I replaced my brakes I bought all the parts from FCP Euro specifically for the lifetime warranty. I think its worth it for expensive things like brakes. next time I have to replace them just send all the used parts back and get store credit.
Thanks so much for all the info and details! I've watched some videos on the swap out on pads and rotors and what I cant seem to figure out is if I will need a specialized tool to compress the pistons on the caliper. I believe on the C400 I have a 4 piston caliper and I know they have to be compressed at the same time so I think I need a specialized tool but just not sure which one I need to fit my model.
Appreciate any guidance you might have.. Jeff
But i've only done single piston calipers. Im not exactly sure how a 4 piston needs to go back, if they have to be pressed in each side at the same time. I'll post what it says for pressing the pistons back and the tool. They have various ones on Amazon, Ill show an example.
https://a.co/d/0mppfM3
