Quick loud squeal noise on downshift
Old Apr 26, 2025 | 05:51 AM
Jakey180's Avatar
C204 c250 coupe with AMG upgrade pack
Hello guys!
just noticed a (drive belt like) squeal coming from my car (C-Class c204 C250 M271 722.9 transmission) on downshifts
only happens when I’m downshifting at high rpm’s or in sport mode.
however my transmission isn’t jerky nor does it slip.
(it can’t be the drive belt as I have a new one in)
I don’t hear it when parked and bringing the engine rpm up higher.
i did notice my wheel bearings have to be changed but I’m not sure that’s it.
The sound can come one regardless of cornering, going straight, up or down hill doesn’t matter it’ll do it.
does anyone know what’s going on?
Old Apr 26, 2025 | 06:29 AM
chassis's Avatar
2017 GLE350 4MATIC
Belt, pulley or tensioner.
Old Apr 26, 2025 | 04:10 PM
TimC300's Avatar
Cant really say that it cant be X because its new. It still could be a faulty part or the wrong one. Not saying its your drive belt, just saying you cant rule it out until you rule it out.
You mention it sounds like a drive belt. If it were me I would put the old drive belt back in and see if the issue still occurs. When I replaced my drive belt I kept the old one in the trunk just in case.
Did the issue start after you replaced the drive belt? What other work have you done to the car recently if anything?
What size, brand belt did you install?
Old Apr 26, 2025 | 05:16 PM
RobertR728's Avatar
2014 c300 w204.080 3.5 v6
You don't say your year or engine but if you have the 276 v6 engine it could be the PCV system that has a torn diaphragm. Especially if it only squeals when hot.
Old Apr 26, 2025 | 06:37 PM
Jakey180's Avatar
M271 1.8L turbo petrol - 722.9 7G transmission
Old Apr 26, 2025 | 06:46 PM
Jakey180's Avatar
I should probably also mention I don’t hear the sound when bringing the rpm up in parked or neutral
Repco - 6 rib x 2315mm
Old Apr 26, 2025 | 06:50 PM
JettaRed's Avatar
Veteran: Army
Grab some belt dressing at Walmart or your local auto parts store and give it a squirt. If the noise goes away, it's your belt.
