M272 Engine Same for Manual & Auto??
Old Jun 14, 2025 | 05:58 PM
subydude81's Avatar
I have a 09’ c300 RWD manual and am looking to replace the engine. Will any m272 engine from the C class work from 2008-2011 and does it matter if it came from an automatic?
Old Jun 15, 2025 | 06:33 PM
subydude81's Avatar
Anyone ??
Old Jun 15, 2025 | 09:35 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Originally Posted by subydude81
Anyone ??
Manual transmission W204s are rare - maybe non-existent in US C300 models. This will take a while to circulate around the world.
Old Jun 16, 2025 | 09:36 AM
JettaRed's Avatar
Veteran: Army
I had a 1999 Audi A4 that I converted from automatic to manual. The job turned into a PITA as the crankshaft end where the tranny mounted was different between the two transmissions. Also, the mounting points on the frame for the manual were in different locations. Fortunately, I had a good shop doing the work and they were able to make everything fit. So, you are smart to check. Not sure if they are different for Mercedes.
My EPC is for US models. Not sure if it covers non-US models, so trying to look up different part numbers for the crankshaft may not work.
Please post your VIN and I will try to see if different crankshafts are listed.
