W204 C250 Sedan Radio Issues - PIN/ Radio Wire Layout
Here is the radio layout for my car and assume other W204 if you have similar connections on back of radio. Hope this helps someone else. I spent many hours mapping each wire out and where it went and check continuity. Tip - I used two sewing needles in pins on connectors to check continuity with multimeter. Helped out tremendously to test cables and find them. Also tested if they were broken or grounded somewhere.
Radio
White - Dual Antenna (Farka)
Green - Nav (LVDS) - grey in glove box
Pink - Armrest USB
Grey - screen (Blue on back of Screen)
Yellow - BT module Overhead light (Farka)
Radio Harness
Black Connector in harness (small)
All connect back to Nav Connector
clear, brown, yellow/tan (2 pairs)
White Connector in harness (small)
Clear, black - goes to Telematics unit behind seats in trunk
Clear, Orange, Tan, green - goes to MIC above Overhead light in top of rear mirror
black, black/yellow - in Nav Connector
Center Plug area (pins) in harness
Red thick - power
Brown thick ground
Brown/Red, Brown - Can Bus
Black/Blue - wake up
Media interface Module
Blue LVDS / Metal connector - armrest MMI connector (aux)
MOST fiber/power opposite side
MOST Fiber routing in order
Radio -1 (Master)
Amp (Driver side trunk) - 2
Sirus Module (center trunk behind seats) - 3
Media Interface module - glovebox - 4
Back to radio (Loop)
Telematics
No fiber - attaches to radio with black/clear wires
Connector - no idea where they went
Couple Antenna connectors (Farka)
Amp
Drivers side trunk
Fiber
Big Connector - Speaker wires (Twisted), power/ground, wake up (black/blue), Yellow/black (unknown)
Sirus Module
Power/Fiber
Blue Antenna (Farka)
MY Radio Info:
OE Radio with Two issues (MOST / Telematics Audio Muting)
523 PA1138D0996285 2
Used Radio
523 PA1138D0806911 6
Front (NTG 4.5)
Back - label connections
OE Radio
New Used Radio
