P0252
Old Aug 2, 2025 | 08:32 AM
Chip2366's Avatar
P0252
I have a code of p0252 on my c220 and it says ...
mercedes c220 output 3 for power supply to the sensor has an electrical fault open circuit
I have no clue does anyone have that same problem at all
Old Aug 4, 2025 | 05:53 PM
TimC300's Avatar
What engine do you have? Diesel?
I look up that code and im finding P0252 is something about the fuel pump?
What obd scanner are you using to check the codes?
Old Aug 5, 2025 | 02:37 PM
Chip2366's Avatar
P0252
I am using Delphi and also autocom
Old Aug 5, 2025 | 03:59 PM
RobertR728's Avatar
2014 c300 w204.080 3.5 v6
Have you replaced any sensors with generic sensors?
I have seen this code any many others from a non Mercedes sensor that causes can bus errors.
You will need a Mercedes specific scanner that can see the can buss and see if there are any errors.
Hopefully its a easy fix.
