View Poll Results: how much power will there be after such stage 1?
300-310 H.p. 280-290 N.m.
0
0%
310-320 H.p. 290-300 N.m.
0
0%
290-300 H.p. 270-280 N.m.
1
50.00%
280-290 H.p. 260-270 N.m
1
50.00%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
I want to chip the M272 3.5 engine and how much power will it add?
Old Aug 23, 2025 | 01:54 AM
David M272 c350's Avatar
Mb c350 w204 2009 4 matic
Guys, my engine has stock values ​​of 272 hp and 240 NmI want to make stage 1 by flashing the gearbox and engine and also change the stock manifolds.How much will this give in hp and Nm in total?
Old Aug 24, 2025 | 08:02 AM
JettaRed's Avatar
Veteran: Army
It will give you probably as much hp as sticking a turbo badge on your car. Gains will be negligible and not worth the expense unless you think 10hp is significant.
Old Aug 24, 2025 | 10:21 AM
TripleDown's Avatar
2014 S63 2010 ML350 Bluetec 2009 SL550
What he said - you need a turbo motor in order to see any meaningful boost from an ECU swap or flash. Headers may net you a few hp up top at the expense of torque down low. Probably not a good move unless this is a track car.
Old Aug 24, 2025 | 10:24 AM
gav24v's Avatar
W204 C250 Sport (AMG Package with Pano Roof)
There really is little point with stock mechanicals and a naturally aspirated engine. No boost to increase you see.
A TCU tune could make it feel snappier and more responsive, as would a throttle pedal tuner. Set up correctly these devices can improve subjectively, the way a car drives. Mercedes have notoriously conservative drive by wire throttle potentiometer curves. I have a roar pedal on my C250. It transforms the car. BMS make a decent unit too, but I like the Bluetooth connection on the RP.
