C250 fuel pump control module
Old Nov 27, 2025 | 05:27 PM
aniline's Avatar
Mercedes r350
He's anyone replaced this with another used one, since you cannot buy new from Mercedes.
Does it need programming?
Old Nov 29, 2025 | 06:18 PM
TimC300's Avatar
It may need to be programmed.
Old Dec 1, 2025 | 01:00 PM
RobertR728's Avatar
2014 c300 w204.080 3.5 v6
Look on eBay and try to check seller description. Most time they will tell you what car it came from. If you can find one that matches your model it might just work without coding.
Example
If you were to but day a window module from a conversable and you have a hard top. The modules will work but it'll want to roll down a little at the top because the conversable rolls the window up a little at the end to drive into the weatherstrip.
If you were to buy used widow module from a hard top the module will be coded correctly when you get it.
