Help please! 2 issues
Old Jan 3, 2026 | 04:17 AM
Arlmeroc18's Avatar
2014 C300
Is this as far in as it's suppose to go? Im finally putting the engine back together but that's as far as it tightens?also can you share the website and program you guys use to figure out bolts and locations please?lol the reason I got in this mess was because of that, im assuming the flywheel is the part that i keep missing, should be held to tighten bolt all the way right? Wanna make sure, not trying to break and take apart again.thank you
Also this inlet tube doesnt go inside the thermostat housing or vice versa, is that how its suppose to be, again dont wanna break anything since I already had to replace the thermostat once or twice?
2014 c300 M276 engine thank you
