Help
Old May 12, 2026 | 09:57 AM
Shawnad6514's Avatar
Help
Old May 12, 2026 | 02:06 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Year? Engine? Mileage? Symptoms?
Old May 12, 2026 | 02:29 PM
TimC300's Avatar
The 0299 could mean boost pressure too low. What are you seeing for boost pressures?
The 2524 coul;d be fuel pump related, not sure. What are you seeing for fuel pressures? Read the low pressure from the pump in the gas tank then im assuming you have a HPFP, whats that reading?
The 0340 may be nothing. erase the code and see if it comes back.
Old May 14, 2026 | 11:33 PM
cvx5832's Avatar
325Ci, 325Cic, C300
My crystal ball says it's your camshaft position sensor.
