How common is the cam adjuster problem on the m276?
Some report this issue at barely 130k kms with perfect oil change history, some are still doing just fine at 250k. How common is it really?
If I catch the cold start rattle early and replace the tensioners and check valve, can i get away with it? Or is the adjuster itself just doomed to fail eventually regardless of what I do?
