As I see it is MY16 (code 806). It look strange without clock. Apart that it is beautiful car.
Do you have Garmin Mappilot? Now should be with livetraffic – how it works?
Since March or April, new productions of code 806 are without clock.
If you choose others you can have clock. I do not have Garmin Map Pilot, it is not ready for Turkish market.
w205 250 4matic automatic exclusive with keyless go, parktronic, distronic plus, active lane keep assist, airmatic, garmin map pilot, ILS, connect me et al.
What would you think of brilliant blue exterior with cranberi red interior?
There aren't many brilliant blues so I couldn't guess how it looks
I had an E60 5er, Monaco Blue with an auburn interior. It was rare, stunning, and I received compliments on the combo everywhere I went. Blue and Brown can work....
Some questions for you...what's with the insulation foil up against the passenger's right leg...where did you get the diamond grill, how much, and was it hard to install?
That foil is Australian for "I'd prefer not to drive an oven"
That is correct! The sun here is quite intense so if you get into a car with leather seat it burns very badly! The sun shield is to reduce the effects and also helps maintain leather as it doesn't dry or crack as fast.
I got the diamond grille from ebay, there is a thread on here floating around discussing it. I paid $270AUD delivered all up. The hardest part was getting the bumper off, the guide that I saw wasn't clear around the bottom two bolts holding the bumper on. If I were to do it again it would only take me 5-10mins to remove the bumper off.
I also found the grille I bought didn't fit 100%, the clips on the new grille extruded out a bit and that caused the rubber shroud that clips in place to not sit flush, however it doesn't impact fitting the bumper back or anything else.
Ah...it's a sun shield for the windshield.
All folded up like that it looked like a piece of plain insulation foil...the same stuff my electric water heater is wrapped with!
Thanks, they are 8.5x20 and 10x20" rear, car lowered using adjustable links for airmatic.
Good am! Your airmatic comes in a package or install it outside mercedes? May i know what exact 20" specs tires you are using front and rear? Thank you
