Hey bro how are you.. Hows the ride quality of 35/30 series. Can you diff with oem 19s? Or is it similar..
good man thanks, although i can't give you 120% answer because i removed the stock 19" right away they ride great. I'm sure it'll be better ride improvement then the 25/30's. that is if they will fit!
Yeah should be better then 30/25 front 35 should not be a problem but il try rear 30 with 285 rear hope it fits.. Hmmm do you have any rubbing issues with 35/30
Ya exactly. And nope perfect fit. Zero rub. Even with full car I'm tuckin in a little bit but haven't rubbed. Our offsets are slightly different so it may be slightly different for yours.
