Track sequence on memory card or USB
Old Nov 29, 2014 | 11:22 AM
vic viper's Avatar
S213
Why does the HU add all available MP3.s together even if they are sorted in folders?
I only have 4 folders with different albums on my current SD but they show up as tracks 0/157 instead of 0/22 on one album/folder
Anyone else noticed this?
Also, is there anyway to fast forward tracks other than tilting the rotary dial left or right?
Old Nov 29, 2014 | 11:34 AM
jbbeauso's Avatar
2015 C400 4matic W205
I have noticed that as well. For me I have hundreds of folders and subfolders. From what I can tell it enumerates all the songs in a way that traverses each folder, then it's subfolders then on to the next folder. It would eventually play all the music. With the search by folder option you are basically just selecting the starting location for the entire playlists.
Old Nov 29, 2014 | 11:40 AM
vic viper's Avatar
S213
That sucks if you know certain track numbers and want to play them, I use the voice control pretty much, and to say "play track 5" doesnt work as well as it used to on my S204
Old Nov 29, 2014 | 11:42 AM
nnk's Avatar
nnk
W205
You can use the touch-sensor/mouse to move back/forward like this:
1. Press middle bottom button on the touch-sensor/mouse once (will bring up the song name, album art etc.)
2. Swipe over the touch-sensor/mouse with one finger (left to right moves forward)
Old Nov 29, 2014 | 01:46 PM
vic viper's Avatar
S213
Yes, but this wont fast forward a track, it will skip to the next.
Old Nov 29, 2014 | 01:57 PM
nnk's Avatar
nnk
W205
Correct .... I don't know if/how it is possible to move even faster (sorry) ...
Old Nov 29, 2014 | 02:40 PM
NYC-Style's Avatar
Corvette/2017 E-300
Options...playback mode...this allows you to select our the tracks are played back
Old Nov 29, 2014 | 03:09 PM
nnk's Avatar
nnk
W205
Mix (or not) only though ;-)
Old Nov 29, 2014 | 03:38 PM
NYC-Style's Avatar
Corvette/2017 E-300
Mmmm...I just checked...selected a specific folder (album) - playback mode: normal track sequence...played track...turned dial to the right...it went to the very next track...etc. etc. Now the one thing I will say is that I've copied my music over to the "media register"...I don't know if that has anything to do with it...
Old Nov 29, 2014 | 05:29 PM
vic viper's Avatar
S213
I dont have a problem with selecting tracks, the thing is that the system adds all the files into one long sequence, so instead of numbering the tracks on folder 5 from 0 to 22 they get numbered from 57-79 if there are 22 tracks on the album.
It also seems that the only way to fast forward a track is to hold the dial right, and that is not always easy.
Just skipping tracks works fine
Old Nov 29, 2014 | 06:08 PM
jolt8631's Avatar
2015 C220 AMG Line Bluetech.
Not got the car yet, so can't try this out, for myself. But if you pull the controller back, to open a Search, then select "Search by Cover" then selecting your Album should display the track list within that Album. With that track list, playback mode, set to Random in current Tracklist "should" only display the Track Nos within that Album?
If not, then I'm flummoxed too....
Old Dec 2, 2014 | 04:39 PM
hpilot's Avatar
2015 C300, 2025 GLC300 4Matic
I won't take delivery of my car for a few months, but here are my thoughts. I am very happy it aggregates all the songs and folders. My current car limits the number of tracks to about 225 per folder and this drives me nuts. I want to put all the tracks into a single folder, and do all the selecting and organizing by ID3 tags. This way you can select by Album, Song, Genre, Artist, Play List, and on some playback devices (Sony) by Year of Release. I really don't understand why you would separate into folders. I have been doing this since mp3s were invented and it works on all modern devices.
Old Dec 2, 2014 | 11:55 PM
NYC-Style's Avatar
Corvette/2017 E-300
I prefer folders because I like to listed to segregate my music...jazz, rock, etc. etc. I have some folders that are a mix of various artists and genere's...you'll notice that even if you're playing an album...the actual track might be track 1 of 16...but in the COMMAND system it may be track 105 of 500. ID3 tags are good provided they're actually categorizing the music correctly...but that's not always the case.
Old Dec 3, 2014 | 08:01 AM
hpilot's Avatar
I understand. I guess I will see that when I get my car in a few months. Generally I don't care about the actual track number as long as it plays in the right order within an album. That said, I usually just play on shuffle.
BTW, I manually code all my tags so the information is always correct - especially genre. I know most people don't do that. In any case, it sure is a lot better than the crappy head unit I have now!
Old Dec 3, 2014 | 01:25 PM
eaglehorn's Avatar
2015 S205
There's 2 ways of doing fast forward with the touch pad.
I play a lot of 1 hour mixes in my car and you can do the following :
1 ) place your finger on the touch pad and swipe left to right and it will fast-forward what seems to be intervals of 3 minutes - I noticed with single-tracks (5-6 min songs) that this will skip to the next track
2) if you want to "seek" forward just a few seconds 3-5 sec, then place your finger on the touch pad, swipe left to right and keep your finger on the trackpad - It will then fast forward until you lift your finger - So : swipe left to right, and hold
Hope this helps
PS: Btw, please read my comment on your other thread with pictures of your new can if you havent - Im still struggeling with nasty vibrations, and I am now on my 5th workshop visit, and on monday I am getting my 3rd set of tires fitted! - Extremly frustrated
Old Dec 4, 2014 | 01:50 AM
vic viper's Avatar
S213
Hope this helps
Wow, thanks, fast forward using the touch pad is spot on!
I have replied in my thread as well.
Old Apr 29, 2015 | 05:20 AM
sibaker's Avatar
C Class AMG
sorry to dig up an old thread but i've just taken delivery of a new C class and am having the same issue with the track sequence. despite all songs being organised in to folders, viewing the "current track list" shows every song on the whole USB stick. this makes it very difficult to get back to the list of songs for a folder/album and also makes random track sequence pointless as it shuffles through the whole USB stick thousands of songs!
Old Apr 29, 2015 | 11:28 PM
SoCal208's Avatar
12E350, 12ML350, 08C350
What I did in this case : insert the SD into your computer, right click on the tittle, select "rename", add 1 or 2 or 3....to the front tittle of the track, it will play in that order (in the folder or sub-folder). It's a pain if you have a few hundred tracks, but I know NO WAY to get around the xxx.PM3 in the SD card.
Anyone know any better way, please add.
Old Apr 30, 2015 | 05:01 AM
sibaker's Avatar
C Class AMG
i found that using the "folder" view to browse through the USB stick creates the problem, and no matter what you do it seems to think that every track on the disk is all one long track list. so that creates an issue if you go in to "current track list" (shows everything!) or try and do random playback within a track list.
so instead, if you go into the structure via "artists" or "albums" instead, it works properly. selecting an album and then showing "current track list" only shows the tracks in that album as it should, and random playback mode also works within that album
needs a bit of fiddling to tidy up ID3 tags on the mp3's as all that info is based on the tags, and not the file name (whereas going through "folder" option shows itr by file name like the older C class (w204) did).
