Comand sat nav
Old Dec 12, 2014 | 06:23 PM
barnsleyshaun's Avatar
C220 AMG Line Prem+
Comand sat nav
A bit disappointed it's not got speed camera locations on, most aftermarket bits of kit have this as standard, anyone know if there's a way of getting them on there? (UK)
Old Dec 13, 2014 | 07:03 AM
nnk's Avatar
nnk
W205
I think it is possible by copying some poi files to your comand system's hard drive, but can't test/have Garmin myself (and that works fine, using the Garmin poi loader for speed-cams).
I could find this, but it may not be the same for W205's comand: http://www.benzworld.org/forums/general-mercedes-benz/1692160-tool-import-speedcams-comand.html#/forumsite/20548/topics/1692160
Old Dec 13, 2014 | 07:20 AM
jolt8631's Avatar
2015 C220 AMG Line Bluetech.
Yes, you an add Speed Cameras as Personal POIs. You add them as files on an SD Card. You can also set Warnings at different distances.
If you go to the online Manual, and search Comand and Personal POI.
Clearly, I can't test it, until the car arrives - but one of the first things I'll be setting up!
Old Dec 13, 2014 | 08:04 AM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
Considering how advanced much of the electronics in this car are, it's amazing that the navigation system doesn't display posted speed limits. It's a very good system, but even a $100 portable unit gives this information.
Old Dec 13, 2014 | 05:32 PM
tgrx1901's Avatar
C200 AMG Line Premium Plus
The second last post in this thread, mentions getting it working for a W205 and how it was done http://www.mbclub.co.uk/forums/gener...ossible-2.html
Good luck and let us know how you get on
Old Dec 14, 2014 | 01:50 PM
Engr Steve's Avatar
C220 AMG Line
Try pocket gps world. Ive found their camera database excellent in the past and updates are virtually weekly.
There is a thread on their forum somewhere which discussed how you add files to the comand system. Well worth a look.
Old Dec 14, 2014 | 02:41 PM
Merlin1's Avatar
W205 C200 Sport Premium Plus. October 2018. 1497cc with 48 volt battery eq
I have downloaded camera locations from Pocketworld to SD card and installed them into sat Comand as instruction below, then find the option in menu to show POIs on map also switch on sounds for POIs.
Old Dec 15, 2014 | 03:19 PM
C220 AMG Line Prem+
Thanks for the replies, I'll download and give it a go.
