Keyless go issue?
No, because everyone who has had this problem has hit the unlock button several times. Same for the ignition problem ... you can hit those buttons all you want, but it won't do anything. (A couple of posters said they did have success after hitting the unlock button, but I could not replicate that when I tried.)
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
Yes, the fob light does come on. This also indicates that the battery is good.
It's probably not a door handle sensor, since at times the ignition also won't recognize the fob. I've had the doors open, then have the ignition not detect the key; and also the doors not work, but the ignition is fine.
These issues are always temporary, and everything goes right back to normal when the problem clears. My car had no key fob problems until a few weeks ago ... then it just started happening. I have changed batteries on both fobs, but that made no difference.
I think there is some sort of intermittent issue with the receiver in the car itself. I don't think this is being caused by anything in the key fobs.
I dont know if there is an issue with the W205. But it is more likely that it is operator error.
You are probably doing one of three things wrong... maybe all three.
1. Do not place your key near another transmitting key (second car/spare key) or near a phone.
2. Unlock the car before you pull the handle. (just like any car, you have to unlock it before you pull the handle) you unlock the car by placing your hand inside the handle, when the car unlocks, you can now pull the handle.
3. Do not touch the outside of the handle when trying you unlock the car. Only place your hand inside the handle to unlock the car.
If you ensure that you attempt to open you car correctly and it still doesn't open then you should take your car in for service.
I hope it works for you. Good luck
#32
#33
This is not an uncommon problem, and many owners of the W205 have complained about it.
Recently, I had a C300 loaner while mine was in the shop getting the seat covers replaced. The Keyless Go on the loaner malfunctioned about four or five times a week. I replaced the CR2025 battery ... made no difference at all.
#34
I feel as though taking the car in for service will be somewhat useless as this is happening intermittently and apparently does not throw any failure codes. I do, however, plan on mentioning it to my service rep when I take it in for the first service.
#35
2014 CLS 550 & 2004 CL55
OK, It's fixed for now. Had the problem with a new to me (used) car delivery. CLS550 2014. Lots of complicated failures but after reading all this. I changed both batteries. Had to replace 2025's with 2032's. They are both 3V with the bigger number being fatter and longer lasting.
I just went out with one key at a time and unlocked and locked with the remote buttons. Then tried keyless entry and engine start, one key at a time, with the other far off. They both work now, the car says the batteries are low in both keys, so they've ben in my storage for maybe 3 years, so that very well may be true. So I'll change them out and see if that message goes away.
Solution: Wait. Unlock and lock with the key, and then do the handle/keyless entry method and maybe you will be as lucky as I am. For today.
I put the old skinny batteries in just to see, and one of them was dead as hell. So I put the fat battery back in and it works.
#36
Just as a note, the solution for me was an eventual software update for a communications error code that the dealer was able to find. IF an error code was thrown, there is a TSB out for the software update.
