Ipod connectivity issues USB C180 2015
I'm having an issue with IPOD and command system. If I unplug and plug it connects fine, when I leave the car the next time i start the engine they are not recognized and i have to unplug then plug again.
Blue tooth works fine with my Iphone both audio and music seems to be only the USB connection.
seams that there is still no solution for this issue, correct?
I discovered that USB is an issue, but also reconect with bluetooth. Either you take out the USB cable or you need to push a button (when using bluetooth)
In case somebody found a sollution would be very interested.
Regards
Wickiman
The other thing is that pressing the call button on the steering wheel does not bring up the last dialed numbers.
All the cars i have owned had this feature as its a hassle when you call some on and is busy and you keep going through the cycle to dial again
