Max SD card for Navigation POI loading
Old Feb 5, 2015 | 09:40 AM
millsjq's Avatar
Aston Martin Vantage, Hyundai Sonata, E450 Wagon
I am attempting to load some POI into the Navigation system and my 64 Gig SD card is not being recognized. Earlier Mercedes had a max capacity of 8gig before 2011, and depending on what I read 32 after. I have checked in the 2015 Command Manual and can not find a spec. Does anyone know, or have been able to load POIs?
Old Feb 5, 2015 | 03:21 PM
davidmcr's Avatar
2014 C Class Saloon C250 Diesel AMG Line RWD, Nissan GTR
I have a 128 gb SD Card and have no issues loading POI's or playing music from it.
Old Feb 5, 2015 | 10:17 PM
millsjq's Avatar
I must be something wrong. I tried formatting the Card (FAT32) and with the POI file in on the SD or with a folder called PersonalPOI containing the POI file I have the same result. I go to the options menu in NAV, scroll to Personal POI, select and nothing happens. I believe it should provide a list of options at that point.
Suggestions?
Old Feb 6, 2015 | 03:50 AM
davidmcr's Avatar
Hi there,
Sounds correct what you are doing. I will check how my SD Card is formatted, in case there is something there, but what you have explained is what I have done.
Sorry
Old Feb 7, 2015 | 11:07 AM
millsjq's Avatar
David, I cant determine if it is the files I created, my card or my car. Could you possibly email me one of your files that works with your system and if it works with my car then I know it is my limited file creation ability, if your file does not load then it is my car or card. I will send you a PM
Jack
Old Feb 9, 2015 | 04:16 AM
ThompasMB's Avatar
V167 GLE 350 de
Works the SD card (Garmin)in a Mac?
