Replacing damaged rim?
Hey,
Basically, I damaged the driver's side front rim and I need to replace it. It's just that my wheels are "staggered". Is it cheaper to buy a new one or just fix it?
Front 225/45R17
Rear 245/40R17
2013 C250
The sizes you are quoting are tyre sizes and not the Rim width, which will be 17x7J, through to 17x 8J, depending upon model. I don't think any of the W205s have an 8.5" Rim, as stock (ie 8.5J) - but happy to stand corrected. I believe the W205 uses the same Rim size back and front, it is just the tyre sizes that is "staggered".
There are a range of tyres that you can fit onto these rimes, but it is important to get the correct combination for the car as the same tyre, fitted on a 7J rim will have differing characteristics, if fitted on an 8J Rim, because the agle of the sidewalks will differ.
