Old Jun 24, 2015, 11:48 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Maintenance
Print Wikipost
Agility Select on Command screen
Old Mar 1, 2015 | 09:08 PM
alkam2's Avatar
2015MB C300 4matic, Lexus NX
I just picked up a 2015 MB C300 4 matic yesterday.
The changing of the Agility select setting from the command screen is confusing. I know that the default Eco, Comfort, Sport, Sport+ mode cannot be changed. BUT when you select that from the screen - you can actually scroll and change the settings, worst of after changing them if you select back or go to another screen like radio then go back your changes are gone, and sometimes a mode is changed even if you didnt.
Then I figure out to start the engine and click the Agility Select button and select Individual mode - the non screen the window with the ADJUST option comes up, select that and make changes - but it acts the same way. It looks like the I mode even though when you click adjust and you can scroll thru all 4 modes and change the steering, comfort, A, it really only allow you to save one setting because when I go back to this screen - settings move around again.
So here's my question
1. I wanted to make sure I didnt mess up the default 4 modes.
2. Now looking at the screen and going thru the 4 modes their settings are not what I want nor same as default before.
3. Can I customize each mode
thanks
Old Mar 1, 2015 | 09:22 PM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
Changes can be made while you are in Individual mode. Those settings will be remembered, but you must be in Individual mode each time. The other modes are not affected by what is done while in Individual Agility mode.
