Burmeister Speaker Rattle/Buzzing - Video Recorded
#126
Interesting, since there is no difference between a "Burmester" door speaker and an "Audio 20" door speaker, other than the A20 gets a plastic grille and the Burmester's is obviously metal.
My guess is that the black plastic grille has enough give to keep the A20 from buzzing where the metal grilles do not.
snowpunk84 (05-04-2021)
#128
First time poster, been lurking for a few months now. I bought a 2015 C400 about 3 months ago, and being pretty particular with my audio, I noticed the speaker buzz the first week of ownership. I'm very happy to report they were finally able to completely fix the buzzing. After having their technician look at it and replace one of the speakers, which didn't make any difference, they checked out other C400's they had on the lot and found they all made this noise. The head of the service department put in a technical case to Mercedes and they responded saying there were speaker brackets that could be ordered that fixed this buzzing. Brackets were ordered and installed, now the buzzing is completely gone! I tested it with the frequency generator app (which the technician was impressed by by the way) and I found no buzzing whatsoever. Wanted to let you all know there is a fix available!
FYI, I have the Burmester system, just to clarify.
#129
I notice that both of you guys who had the fix performed are in Canada. Has anyone in the states had the repair. I called my dealer today and they said they would look into it but that hasn't meant much in the past.
#130
Anyways, after they heard that, they wrote a report to Mercedes in Germany stating the issue, and they came back to them a few days later saying that there is now an 'official' fix for this known issue.
So I brought my car back a third time, and they were finally able to fix it.
#131
I was able to get it fixed in the states on my 2016 c300, the service bulletin on the work order is LI72.10-P-061465 . So far it seems to have corrected the issue.
#132
Hi.. Can you describe in a little more detail what exactly that work order entailed and what it fixed? I'm noticing more and more buzzing in my front right and left speakers at the 250-280 Hz range and I am taking it to the dealer on Monday. Would really like to do some good research on the issue/fix beforehand since my dealership's been known to be very picky when it comes to fixing what they view as "small" issues...
#133
#134
Originally Posted by Matts2015c300
sounds like you need to find a new dealer. Mine just replaced the door clips and tweeters after the first dealer completed the "TSB" and gave me the car back with rattling speakers. The second dealer rolled there eyes (at my first experience) and fixed it correctly in addition to replacing my front glass with acoustic. I don't understand these dealerships. Good luck!
#136
Update: I just received the car from the dealership after it being there for 3 days. My SA really went above and beyond to fix this issue and I'm pretty satisfied with the results. They ordered new front speakers for me and installed it on the 2nd day but told me they were still hearing the buzzing noises and had to get in touch with MBUSA. Apparently, MBUSA said that it is a common issue and the only remedy is to install felt tape and insulation in the doors that have the problem. My SA called me and asked if that is okay and I said sure thing, and they actually insulated and installed felt on all four doors plus the center dash speaker even though my only complaint was for the front doors.
After testing the system for about an hour now, I can say the problem is pretty much gone and the Burmester system is sounding really badass. While at the dealership I tried my tone generator at the frequencies that used to buzz and I was really surprised there was absolutely no buzz even at really loud volumes. Also tried phone calls and some songs that used to produce that buzz and it is completely gone!
Couldn't be happier with the results so if anyone is interested in the exact wording of what was performed on the car I can post it on here sometime. Just wanted to report this update for other users out there who have the same issue.
#137
Thx man and glad it's fixed for you!!!
#138
C8, FF, C63S, 911 C4S, GTI, E350, Boxster S, 355, Esprit S4, Vantage, S5, Z4, M3, Miata, A4, 325is
"only" going with the Bose this time as I'm really disappointed by this experience.
#139
Search on this thread and you will find the answer or the link to your answer as it has been posted before. For me, I can easily replicate with the music I play (heavy bass).
#140
The issue isn't with the "Burmester" speakers, which are actually a common off-the-shelf 4" Harman/Kardon unit that's been used in BMW and Mercedes for decades. It's with the metal grille and the way it's set into the trim. Certain frequencies create a harmonic vibration between the grille and the trim. The felt tape dampens the speaker grille and stops the vibration.
Here are some side by sides between the "Burmester" 4" mid and tweet vs the Harman/Kardon 4" mid and tweet from a W221 S Class.
W221 Harman/Kardon (left), W205 Burmester (right)
#141
The frequencies that caused me issues were from 230 Hz to 280 Hz. I've uploaded some test tunes I put on a flash drive and kept with the dealership while they were fixing the issue so that they can test it. You can also just call any customer service number (I called Time Warner Cable) and if you turn up the volume just a little bit, the speakers start buzzing. Also, some songs that I noticed really produce the buzz are Mercy - Shawn Mendes, i hate u i love u (just the first few seconds) and Fake Love - Drake. So, I also left these on the flash drive. Feel free to download the wav files I attached and test them out. When I tested it at the other cars in the dealership, they all produced that buzz. Fortunately, the felt tape fix remedied that issue completely so in a sense the current system I have is better than a new one.
SpeedingTicket (04-15-2017)
#142
#143
#144
Sadly, aside from Mercedes licensing the Burmester name, there are no Burmester components in the 205. Not the speakers, and not the DSP amp. Burmester itself is a builder of audiophile home audio. They don't produce or sell car audio. It's possible they had a hand in selecting components and tuning, but Mercedes hyping the 205 "Burmester" is kind of a joke. Even when it's functioning normally it's not a great system. For casual listening at moderate volume levels it's adequate. Mine was in the car for about two weeks.
alyshehata (11-03-2016)
#145
#146
#147
Cannot believe it's taken this long for them to solve this. I'm just glad I returned my C63S when they wanted to break all the clips and glue the speakers in place over a year ago. Back with a BMW and my M5 is absolutely rattle free in all areas compared to the C63S that had a rattles and issues in most places.
I miss the exhaust note and the style of the C63S interior looked nice but ultimately BMW just feels so much better put together. I'd consider a E63S for the next car but then I've read the new E class isn't exactly well put together either which is a shame. Mercedes need to do better.
#148
w212 E350 Bluetec & Mk7 GTI Sport
I hear this too. They did the manual hand modification of the speaker clips, which 'helped' the rattling with no music playing.... but during { any quality of song, or type of music... with surround on/off, equalizer on/off, volume high/low, bluetooth/usb/cd/satellite, bluetooth volume enh off/on, } i infrequently get a very low frequency distortion. NO way around it that ive found. At certain times it will make this very noticeable sound to those who are audiophiles. A video has a hard time illustrating just how unpleasant the sound is.
HK and Burmester seem to use the same sort of software that augments the outgoing sound to enhance acoustics/treble. Some earbud technology came out with this...I think i threw them away after all, and they were like 140 bucks...
Not to mention, Theres no way around the fact that these speakers are attached to a small amplifier......
#149
I've had the "Burmester" speakers out of the car. Not only are they like crappy HK, they are crappy HK. No Burmester hardware whatsoever in the car. And yes, a very small digital amp. I guess Burmester signed a license deal and possibly did the tuning.
Also the door speakers are all on passive crossovers, with a cheap capacitor glued to the back of the cheap off-the-shelf silk dome tweeters. That and the lack of any proper midbass woofers, leaving the boomy "Frontbass" speakers to play way up into the mid range. That's why, while the system is passable at lower volume levels, when you roll it up the mix disintegrates. The mids get shrill and overpowering, and the bass goes loose and sloppy.
I get that metal grilles are snazzy, but is anyone shocked they buzz? I'm wondering if the problem is more prevalent with the metal door trim vs the ash or lindenwood. Mine didn't buzz either with the OEM or Focals.
#150
Do you have to remove the door panels to get the speakers out or can you access then through those snazzy metal grills? I have the coupe....
