Audio Questions
For those of us who have devices we'd simply like to "play through", has anyone found a solution to go from USB male to a 1/8" male connection that the car will play without trying to recognize the files and generating an error?
"Use this item to charge and transfer files to your audio device, or some other devices that uses a 3.5mm DC jack. Compatible with ipod shuffle 2nd gen, ipod 3, and some other mp3 players.
It can also be used as an audio wire, but only if the usb device already transmits/receives audio signals. The wire does not convert data signals into audio signals, or vice versa."
The question is whether the car receives audio signals or files. It seems that the USB is receiving file information and then using a codec to play the signal through the speakers.
