Did you know?
Old 12-15-2015, 01:04 PM
  #226
darwin329's Avatar
w205 c400 c63s
Maybe everyone knows... Il just post it anyways.... Try leaving your keyfob in the trunk close it then trunk will pop out right away.
Old 12-15-2015, 02:23 PM
  #227
jolt8631's Avatar
2015 C220 AMG Line Bluetech.
Originally Posted by kkkat
I noticed if I hold either of the shift paddle for a little longer it does the following.
1. while cursing, holding the downshift paddle will downshift to the lowest gear possible.
Haha - you don't saying WHO is doing the cursing... Is it:
a) Driver - "I'll show this f****ing car who's boss - take that, you bas***d!", or
B) Car - "Let go of my f***ing downshifter, you b***ard! Don't you realise that if you do that I'm going to throw up gearbox oil and cogs all over the road... That'll teach you!"
Old 12-15-2015, 02:35 PM
  #228
kkkat's Avatar
CRV
Haha. Good one! Will fix the typo.
Old 12-15-2015, 05:02 PM
  #229
DBOC205's Avatar
W205 C250BT
HAHA.. first time I noticed that I though the car was broken because I inadvertently left my key in a work bag which I put in the trunk. I was standing at the back of the car like an idiot cursing ".. well that's just great - now the darn lid won't close!"
Old 12-15-2015, 10:06 PM
  #230
darwin329's Avatar
w205 c400 c63s
Hahahaha! Thats actually how i found out about it lol..
Old 12-16-2015, 06:41 PM
  #231
realness101's Avatar
2015 C300
Does anyone have issues closing the gas tank door? I have to do it couple times to get it right.... Is there a special trick to it?
Old 12-16-2015, 07:38 PM
  #232
cajun1689's Avatar
2018 E63S: Former cars 2016 C450, 2013 C350, 2009 C300
car cant be locked.
Old 12-16-2015, 08:54 PM
  #233
Matts2015c300's Avatar
2015 c300
You probably have a poorly aligned tank door like I had. I used to have the same problem before it was replaced due to poor alignment. Now it closes perfectly every time.
Old 12-16-2015, 09:08 PM
  #234
2015 C300
I think this may be my issue. My doors are unlocked but I keep closing it, but it pops right open. Now I just fill up my tank all the way every time .
Old 12-16-2015, 10:52 PM
  #235
gfmohn's Avatar
2021 E450, 2020 C43, 2015 C300, 2007 C280
Sticky fuel door
I had the opposite problem. I would have to poke the door several times before it would pop out for fueling. I sometimes thought that I might have to use a credit card to pry it out. The gaps around the door were not even, and the top edge of the door stuck out. All in all, this was not what I expected in the way of fit-and-finish from an almost $55,000 (MSRP) luxury car. As with Matts2015c300, the dealer had no problem simply replacing the door assembly and got the gaps right. End of problem.
Old 12-17-2015, 01:32 AM
  #236
whkento's Avatar
'15 C200 AMG line, '08 C300 Sport Avantgarde, '07 Jeep Grand Cherokee Ltd, '02 CLK 200 (gone)
I've had this issue a couple of times. Not sure why.
I also couldn't open it once. The gas station attendant told me to unlock the car. I felt stoopid.
Old 12-17-2015, 07:01 AM
  #237
jolt8631's Avatar
Originally Posted by whkento
.I also couldn't open it once. The gas station attendant told me to unlock the car. I felt stoopid.
Classic.
Not sure I would have shared that one, though...
Old 12-17-2015, 09:53 AM
  #238
rbrylaw's Avatar
2019 E450 4Matic & 2018 E400 4Matic
Classic.
It made me like him even more! It reminds me of when I got my first ever iPhone. The 3G. I was styling then, for sure. Only all of the sudden, I couldn't hear my phone ring, nor get any alert sounds. I walked right on into the AT&T store and claimed there was something wrong with my phone. The guy looked at my phone, clicked the mute switch back up and handed me my phone and said, "sir, next time, check the mute button!" I felt stoopid as well........
Old 12-17-2015, 04:51 PM
  #239
BlackC400's Avatar
2016 C450
You can use the MBrace app to start the car for 10mins even if your out of the country on a long vacation 👏🏽
Old 12-17-2015, 05:08 PM
  #240
2015 C300
So I own a 2015 c300 , It had a few thousand miles on it. I wanted to know if there is a way to reset the car so it can used to my driving behavior and not the previous owner.
Old 12-18-2015, 08:29 PM
  #241
CO2010's Avatar
2015 C300 RWD Sport Premium
I hurt my back today so I figured I would use the heated seats to help relieve some pain. I learned that if you have it on level three, its highest setting. After a few minutes it automatically switches down to level two. A few more minutes level one. Then eventually shuts down.
Old 12-18-2015, 08:40 PM
  #242
gfmohn's Avatar
Throttle reset?
I have seen these instructions in several different posts. The only mention in a post specific to the W205 models comes from a post from the well-known Glyn M Ruck https://mbworld.org/forums/c-class-w...CU#post6273669:
Door closed!
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
All this does is the align the throttle body throttle plate with the pedal. So full pedal movement = WOT. Sometimes loses calibration.
Unlike other commenters, Ruck does NOT claim that this procedure resets the ECU. Nonetheless, this may help. In the long run, I would expect the ECU will learn your driving technique. I don't know what period it averages.
My guess is that you are not concerned that the previous owner was a boy racer, whose pattern of use has made your car too responsive for you! If the previous owner was more conservative than you are, he or she probably never used the Sport or Sport+ modes. They would remain at their factory default settings.
Old 12-19-2015, 01:56 AM
  #243
cyberorth's Avatar
2018 AMG GTR, 2017 GLS63, 2019 C63s
Most tuning companies disconnect battery for 8 hours or more as a general solutions.
Old 12-19-2015, 10:34 AM
  #244
topsider's Avatar
2015 C300 Sport 4MATIC
http://www.benzworld.org/forums/w212...-learning.html
Old 12-19-2015, 02:36 PM
  #245
*Knowledge*'s Avatar
The Infamous C450
Is there a way to disable the 'Don't forget your key' chime when you enter/exit the vehicle?
Old 12-19-2015, 04:56 PM
  #246
cyberorth's Avatar
I wonder if you take the engine start button out it would stop that.
Old 12-19-2015, 05:37 PM
  #247
The Infamous C450
Just confirmed, that does not work.
Old 12-19-2015, 09:15 PM
  #248
gfmohn's Avatar
Exclamation Be careful
I wouldn't do that without expert advice. I believe that, for openers, you will lose all your settings, radio and so on. I know that's the whole point of this procedure, but those tuners may have some way of continuing to power the systems whose settings you want to keep.
Old 12-20-2015, 12:35 AM
  #249
cyberorth's Avatar
That is correct you will lose presets. In my reference, the idea of having to reestablish the radio setting in order to get your tune to work is not even argued, rather accepted without questions. Just pretend you're switching your dead battery. Redoing presets is a given.
It is also the whole point to cut power completely to clear driver learning memory.
On another note when the dealers do this (resetting) they follow a protocol to teach the car the mb standard defaults. The idea is that a new car does not default to a more aggressive driving style directly off the showroom. This can be found on startekinfo and involves specific rituals as well as particular ways of driving a few miles. I was familiar with this with my w204, but not with w205 as I have only had 3 weeks with it.
Old 12-20-2015, 11:03 PM
  #250
gfmohn's Avatar
Question The Quest
I have seen enough of these posts about this quest for ever "more aggressive driving style" that I am finally curious enough to ask a question. Just what are you guys looking for? Is there something that dialing up Sport+ doesn't do? Despite my previous remark about boyracers, I am not putting you down. I realize not every driver wants the same thing.
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
