View Poll Results: Do you have a wind noise problem with your W205?
I have no unusual wind noise in my car.
27
40.91%
I have some wind noise at higher speeds.
26
39.39%
I have some wind noise all the time.
5
7.58%
I have severe wind noise and consider it unacceptable.
8
12.12%
Voters: 66. You may not vote on this poll
Wind Noise Poll: Yes or no?
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
This is a simple poll which will hopefully define the percentage of forum members who are experiencing the often discussed wind noise problem.
Some cars have it, some don't. Country of origin seems to have no bearing on the frequency or severity of the problem.
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Equally this can be user specific in that what one person considers normal may irritate someone else which skews such polls. There may be a car that one owner considers noisy but then another person gets in and doesn't know what the fuss is about.
The wind noise problems that have been discussed on this and other forums describe unusually high levels of wind noise under normal driving conditions. They have been described as sounding like driving with a window open, or a constant fluttering sound. That would certainly qualify as unusual, as well as very annoying.
That's why I worded option one as "no unusual wind noise," rather than "no wind noise." No bothersome levels of wind noise under normal driving conditions is what this refers to.
Thank you for that. This is an example of how interpretation means quite differing comments on here. What you consider normal (not unusual) wind noise, someone else may consider irritating levels of wind noise. This is what makes a poll or any of these wind related threads a bit flakey as really you'd need a group of people trying out each others cars and cars from other manufacturers to realise whether or not this is an actual issue.
Here's where the whole "wind noise" issue becomes blurred. There are several sources of noise one might hear in a moving vehicle. These include engine, road, tire, wind, and outside sounds. The wind noise that most of us are referring to is specific to the doors and windows. These high wind noise levels are likely related to an issue with the door or window seals, in that wind noise comes into the cabin through those very well defined areas.
Outside noise can be generated from many external sources, including wind gusts and crosswinds. That has more to do with the car's insulation from outside sound than it does with poor seals that allow wind to penetrate through those seals. So, yes, it is likely that some air flow over or across the body of the car can be heard inside the cabin, but that's not caused by an air leak through the window or door seals.
I have no "unusual" wind noise in my own car, but that's not to say I can't hear the sound of severe crosswinds or gusts at highway speeds. Normally, at speeds up to about 70 mph, I really can't say that either my wife or I have ever heard anything that I would classify as anything but very hushed wind noise. The car is quiet, and I typically get much more road and tire noise than anything else.
Some who have complained vehemently about wind noise, have also admitted that no one else can hear it. Others have stated that they didn't realize they even had a problem until it was pointed out to them.
I think many of us are simply curious to see how many here perceive wind noise to be a real issue with their cars.
Some noise at high speed
I can hear wind noise at high speed 60+ mph (if I listen carefully.. while music is off). when I have music on, and usually all the time, I don't find the wind noise to be annoying.
I have compared my friend's W205, he has less wind noise at similar speed on the same road. But still, mine is not at "unacceptable noise level" or "noise like window is down".
I voted "some noise at high speed".
My personal experience: I only heard wind noise at high speed, but thought it's normal. After I saw threads discussing "wind noise", I listened carefully and started identifying that. I thought I had wind noise.... But it seems it's just normal or a bit above the normal level - still fall into the normal range.
'13 VW Touareg, '15 Harley Ultra Limited, '15 C300 Spt, '14 Airstream Interstate, '16 VW Tiguan
A course of action that I believe would get MBZ's attention is to create a website that informs the public about the excessive road/wind noise with some builds. I for one don't have the expertise to create a website but I'm sure someone here does. I would certainly contribute to a fund to help this happen. Comments welcome.
Seal replacement helped mine a lot. The car had a lot of wind noise, like door not shut. Many of my passengers thought it sounded quiet though. I think this poll shows how well people on this forum can hear, and their tolerance for this specific noise, more than the number of cars with a defect. It's the loudest wind noise car (with a roof) I ever rode in before the fix. Now, it's pretty good. My cousins Chevy Malibu quieter for sure. He paid less too . MB should be ashamed.
What MB should be doing is quietly and proactively contacting each customer that has complained of wind noise and work with them for a resolution if they really wanted to ensure future sales and loyalty. Right now I'd never buy another Mercedes Benz and I'm not even sure how long I will keep this one. However if they helped resolve the niggles im pretty sure I'd hang on to it, be impressed by their service (not so far) and invest in them again.
'18 GLC 300 4M/Air Suspension
I think a lot of the noise is related to "wind". The other day I drove 40 miles North in moderate winds and the noise was terrible. Driving back South, it was barely noticeable. I'm thinking if the wind is hitting the driver's side it is much more noticeable.
Agreed. I suspect the front window channels to be honest. No other car I've owned has this channel at the side of the main windscreen. Smacks of an ideal way to create cross wind noise.
I just got my w205, yes there is substantial wind noise above the speed of 100km/hr
I am not sure if it's normal, but i will test drive their test car unit on Monday to compare. I have also downloaded decibel db to compare the db level. So at least we get a reading.
Mercedes C200 (W205) Avantgarde petrol RWD
From what I read on here there seems to be a different levels of intensity of the wind noise and the poll is capturing that.
The other factor that that I have noticed on not only this thread, but others that address issues with the car are the experiences people are having with their dealerships. I have had mainly positive interaction with the dealership that I purchased the car from and frankly am appalled by some of the experiences I have read on this forum. Ranging from disinterested and uninformed sales staff to incompetence, carelessness and rudeness. This must be incredibly upsetting for people who have spent their money on a product, found it lacking in some way and are expecting a response to their concerns that is consistent with the way MB promotes its high level of customer service. Dealing effectively with consumer complaints should be at the top of any businesses priority list, for a multitude of reasons.
So far, 46% of respondents report hearing no unusual levels of wind noise in their cars, and only 10% find wind noise levels high enough be be considered unacceptable.
Quite frankly, that's not at all what I expected. Both my first C300 and current C300 have essentially no wind noise problems, with only heavy crosswinds generating any sound in the car at all. I thought this was the exception, but perhaps not. I've owned many cars over the years, and I find the C-Class to be at least as quiet as the best of them.
The question remains: why do some cars exhibit high wind noise levels? I wish I had an answer to that.
I voted for the "I have some wind noise all the time." option. I didn't find the wind noise to be SEVERE as you labeled it in the last option but I found it unacceptable to be having wind noise at just about any speed above 45mph, which during my daily commute I am at that speed about 80% of the time. Definitely one of the loudest cars I've owned when combined with wind noise and regular road noise.
