Keyless Go not working - and possible solution
Old Jun 9, 2015 | 11:25 PM
SchneiderIS's Avatar
ML350 BlueTec
Note that I am posting this as a help to anyone else that runs into this issue as I have a solution at the end.
Today my Keyless Go stopped working. Both the ability to open/lock the car and start the car stopped working. I tried both sets of keys to no avail. The kick to open trunk feature also did not work.
Attempts to find a solution in the COMMAND Digital Manual had no references to work with. Google didn't result anything either.
Next I went to find the fuse box to determine if there was a fault there. Looking at the fuses, there are two for the Keyless Go (458 & 460), they were both fine. I made sure the fuses were seated correctly and decided to check the system again. It worked!
Hoping this just happened to be a seating issue and not something else that is going to be an ongoing issue that requires service. When the first service comes they can check to see if anything comes up.
