Garmin Map Pilot with APS20 but without Code355 ?
Old Jun 10, 2015 | 11:08 AM
Master_PiT's Avatar
W205 220 Bluetec AMG 15' / W202 220cdi Esprit 99'
HI.
In my car i have Audio APS20 CD without Code355 (preparation for Garmin)
Today i found this http://configurator.mercedes-benz-ac...C8C6AE3C18442C
And I'm wondering whats the price, and what do i need to buy and replace.
I have only 2USB without SD Slot.
In spec of car i see that i have "GPS Anthene"
is this part enough?::
A2058200126
Or need something else?
Need something encode? Or its just plug and play?
Please for numbers of parts what I need to have garmin map pilot.
And sorry for my English, it's very weak- I Know this
cheers!
Old Jun 11, 2015 | 10:15 PM
seanvree's Avatar
2015 C300
Whoa, I'm interested!
i just checked with my VIN here to see if it's compatible:
Mine says: "This accessory model cannot be used in conjunction with your vehicle owing to technical restrictions regarding model year, equipment or engine."
Old Jun 12, 2015 | 03:40 AM
Master_PiT's Avatar
Do you have audio20 cd with touchpad?
Old Jun 12, 2015 | 08:28 AM
vic viper's Avatar
S213
You need the above part but also a GPS antenna, the retrofit GPS antenna is placed under the intrument cluster and connected to the HU behind the panel.
When finished add SA code 357 and code HU
Old Jun 13, 2015 | 03:12 AM
Master_PiT's Avatar
thanks vic!
But what is HU??
So in my spec of car i see that i have gps antenna installed. So i dont need to buy another one?
Old Jun 13, 2015 | 04:02 AM
vic viper's Avatar
S213
HU - head unit
How do you know that you have a GPS antenna?
Old Jun 14, 2015 | 09:47 AM
Master_PiT's Avatar
i see GPS ANTENNA in list of specification car, so i think it's connected.
Must add codes with STAR DIAGNOSIS or what??
thank you for reply
Old Jun 12, 2016 | 05:58 AM
Rui Oliveira's Avatar
W205
Hi!
Did you manage to get it to work?
My car already comes with GPS antenna but lacks the SDCard reader. Do you know if I could get the maps in (Mercedes-Benz Garmin MAP PILOT 2015/2016 SD-karte Audio 20 A2139060303) with a external SDCard reader through one of the USB ports?
Thanks!
Old Aug 2, 2016 | 05:31 AM
wan197's Avatar
W205 C180
sorry wrong post
sorry wrong post
best regards
wan197
Old Nov 26, 2016 | 09:40 AM
wan197's Avatar
W205 C180
sorry
sorry
Old Dec 25, 2016 | 04:18 PM
wan197's Avatar
W205 C180
Hi all
Whats new width Garmin Map Pilot ??
best regards
Old Feb 11, 2017 | 12:52 PM
zevv's Avatar
Mercedes C220d 4-matic (w205)
Preperation for Garmin (355) cant be recognized
Hello,
This is an old thread, but i have the same question as the thread starter and i cant find any answer for it, so i hope maybe someone tried this.
I have a new Mercedes C 220d 4-matic (w205) 2017 with:
(522) Audio 20 CD with Touchpad
(818) CD-player
(270) GPS antenna
Because i bought my car without preparation for Garmin (355), i thought i could add this by myself. So i order this SD Card input slot plus the Garmin SD-card from ebay. My car has just two USB-slot. Tonight i tried to change the unit in my car, but it cant recognize the SD Card Input slot. The SD-card cant be recognized and neither of the usb works when i put an USB stick in them.
Does someone know if this is because its not compatible with my car model (are there different 355 units)? Can it be due to some code need to be added in my cars head unit. I read about SA code 357 and code HU need to be added with star diagnosis. But i think its strange neither of the USB works in the unit because of the codes is missing. The connectors on the behind of the units look exactly the same.
Old Mar 7, 2017 | 03:03 AM
filfergui's Avatar
W205 300h
Hi Zevv,
Did you get trough the problem with the gps unit? Could you please advise me what is needed? I also want to by the part number A2058200126 but do not know if it will work.
Thanks in advance
Filipe
Old Mar 7, 2017 | 04:44 PM
filfergui's Avatar
W205 300h
Anyone? Thanks in advance!
