Head discolouration!
yes, you can take it back to your dealer, but I suspect they will paint/replace at your cost, I'm afraid.
Fact is that rubbing action - even against relatively soft items, will quickly damage paintwork, if it is concentrated in a small surface area - that is why something sharp rubbed against paintwork will cause damage, but a large surface area, moved with the same force, will not do so much damage.
However in this case the OP clearly says the problem only occurred recently and he's been parking the car against a shed where there could be "soft" plastic rubbing against it.
I don't know any sheds with soft enough plastic not to take the clear coat and paint off of the creased edge of a car part if it rubs up against it for a while.
