Excessive Wind Noise Captured on Video
Digging around the internet, I've found quite a few discussions about wind noise. The vast majority blame the inability of the car to seal properly, typically because the seals are defective or poorly installed.
I found this Lexus thread particularly interesting (does it sound familiar to you?). If you look at the discussion around Dec 28th, 2013, abcsoup shows some diagnostics he was using to isolate the problem (and, it seems, temporarily solved the problem).
Maybe it's worth trying something similar on noisy C Class cars to find the specific culprits... especially if that can be used to demonstrate that seals (or improperly fitted doors) are the problem.
The thread I'm referring to is here
http://www.clublexus.com/forums/is-t...ow-door-2.html
2015 C300
I'm thinking that it was "designed" to have the whooshing sound that I hear from the passenger door. I highly doubt that they will try to argue that the flapping sound from my driver's door is supposed to sound that way seeing as the passenger door doesn't make that sound. If they attempt that, I'll make sure to ask them to give me a technical explanation of why the driver's side door and passenger's side door are supposed to sound different. I'll also be sure to ask them if they believe that 100% of C-Class vehicles around the world have a 0% possibility of any wind noise defects. If they say "Yes", then I'll ask them to give me that in a written statement.
Best hope is to find a dealer who will change your weather stripping for door and glass under warranty and hand install it. Second best is to beg them for acoustic glass and pay for that out of pocket unless you have friends in high places. Per my friend at dealer, their new cars (June 2015 build) still have the wind noise. Though as she says, some buyers say it's "whisper quiet even at 80mph", she can still hear it loud and clear.
I'm sure Mercedes will put out new weather stripping. They are known to do that and just change the part number. As of now, all W205 have the same stripping, and it is very positional. A 1/100th of an inch makes a difference. Thus, why some develop noise later.
2015 C300
How were you able to get the acoustic glass? If need be, I'd be happy to pay for that out of pocket as I know it would be like 1% possibility of MBUSA giving it for free. Did you have to struggle with them to allow you to purchase it?
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Very windy today, crosswinds on the motorway sufficient to push the car around. Wind noise is significant if no music playing in car at speeds over 50mph. Wind noise sounds like it's all over the top of the car rather than door seal specific. id consider wind noise in these very windy conditions to be inevitable but still it's louder than any car I've owned.
#32
Today's Observer newspaper here in the UK had a review of the C300 hybrid:
http://www.theguardian.com/technolog...amg-car-review
As soon as I read one paragraph, I thought of this forum and then wondered if they were reviewing the same car, given all the problems on here:
The car is as smooth as a shaved shin and has virtually no wind drag. This means there’s little buffeting and road noise is minimal. It’s incredibly quiet on the road. An executive doesn’t want to be troubled with background chatter.
#33
Well that pretty much describes my car
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
#34
2013 C class Coupe 250 CDI
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
#35
#38
Interesting read. Are these wind noises happening on new cars from day 1?
Or is this issue after a few thousand miles?
I did notice that the two different owners are driving on both sides of the car, so is the noise only from the drivers' side in their respective country?
If it's driver's side only, then it must be worn seals.
This C-class supposedly has the best drag coefficient in it's segment (.24), so air management shouldn't be an issue.
The noise in the videos sounds like it's from the A-pillar.
You might want to try using "gummi pflege" on the door seals to refresh the rubber seals and see if the noise goes away.
#41
Mine was quiet as a mouse, until we had some hot/cold spells and then it whistled louder than you could turn up the stereo in a crosswind. The dealer at first drove all the W205 on the lot, was about 10 of them, and they all had the 'noise', though his mechanic said he didn't hear it, the manager did. I ended up getting the new seals and window run as reccomended on the board and it helped a lot. Not as quiet wind noise as a basic Kia, or most other cars, but is better. I'm on the trail to get the acoustic glass. Easier said than done here, but our European buyers can get it, it exists.
#42
#43
My 02. Have 2015 ML250. Not a very aerodynamic box. Recently drove from Cleveland to Chicago @ 70mph into a strong headwind. NO wind noise & I have not heard any wind noise in the 6,000 mi that I have put on my ML. Just posting this to illustrate that if Mercedes can make a big box SUV quiet there should be no problem with doing it on the new C Class.
#44
2015 C300 4MATIC
MY15 C300 4MATIC sedan. I can hear the exact buffeting/flapping wind noise as in these videos when running my car at above 55 mph in windy conditions. My car was built in June 2015.
I agree, air circulation button cuts down the overall wind noise, but the buffeting/flapping noise still clearly stays on at the same intensity.
Oh I'm 200% positive that it's not coming from the climate control air vents. I know all about the air vent noise, and I make sure to recirc when I'm on highway/freeway speeds. It definitely cuts down on the overall noise in the cabin, but it does nothing to reduce the excessive wind noise coming from the window.
#45
2015 C 220 CDI
I was hoping that my newly delivered car manufactured July 2015 would be free from this issue after reading the forum for months now, but unfortunately it isn't. It's not THAT annoying and it was the first thing I was looking for as soon as I got it few days ago, but it's definitely there.
Not really sure if it's worth mentioning it to my dealer considering the answers people here received.
#46
I have only been driving the car 2 days, but have been above 80mph and have not noticed any wind noise or excessive road noise.
For me, this car is complete quiet luxury. If I do find noise to become a nuisance, especially when driving longer journeys ill let you all know
#47
2015 C300 4MATIC
I think wind conditions play very important role in whether or not you hear this noise.
Same goes with road noise. Road quality here in Michigan is not that great and I get a pretty noisy ride.
#48
2015 C 220 CDI
I am in the same situation. I want to go and complain to the dealer but not sure if its gonna be of any use at all.
However I am more than happy with road noise, or better said lack of it. In that departement the car is really quiet. One of the first things family said was how quiet it is. (on the other hand we came from C63, so ride and acoustic comfort is like in S-class in comparison
#49
2015 C300 4MATIC
Overall sort of like bad pixels in a display or sensor, your almost certainly better off not looking for them.
#50
Same thing with my July MY15 build. Its definitely there (seems to become noticeable around 60) but not that annoying. Car is otherwise very quite and even at 75 the wind noise isn't noticeable if I have the radio on.
Depending on your dealer, and moreso your adamance, you can get new window runs and door seals installed, and push the dealer to get you acoustic glass. No will be there first answers, but I'm proof they will do it. There's glass for this car that's DOT rated, MBUSA just not offering it here, interestingly, it's just a tiny bit thicker, about a mm. Enough that it might explain the loose seal on USA windows.
The car without mods has too much wind noise in a crosswind for a basic $14k car, much leas a $50k one.
