De-mystifying: Active full-LED lights vs LED lights
Old Jun 28, 2015 | 02:55 PM
True101's Avatar
2015 MB Sprinter RV
I think we all know that Lighting package gives headlights that dynamically adjust the headlights, automate the low and high beams as needed and illuminate the corners. But those are all characteristics while driving.
My question is: what are the differences between these 2 kind of lights from a purely physical appearance perspective? (like when the car is standing, could someone with experience on both, narrate the physical appearance characteristics and how the one or the other looks more sharper ... i personally cant tell the difference)
Old Jun 28, 2015 | 03:07 PM
jolt8631's Avatar
2015 C220 AMG Line Bluetech.
OK, I'll try to explain - but personally, I was more interested in the performance of the lights, than the minor differences in appearance, but anyway.
Looking at the lamp units, from any real distance you not really see any differences. The physical look of the light is, after all, dominated by the DRL LED.
Get up closer and the LED units look slightly different as the lights need to swivel left/right - nothing major.
In addition, the active lamps have a further LED unit embedded into the side of the unit, right at the front - this is there to shine out to the side, to light up side streets, when turning. These are very difficult to spot.
The only other real difference is the "Intelligent Light System" embossed in the reflector.
Hope that helps.
Old Jun 28, 2015 | 03:17 PM
MASSC450's Avatar
2026 GLE 53 Coupe
Dynamic LED Headlights...
Old Jun 28, 2015 | 03:19 PM
Mr5uby's Avatar
W205 (on order)
I would slightly disagree with the above. I think there is some more differences (see below pictures of our W205 which has the intelligent light pack)
Straight away there is an additional LED unit as you say, instead of the reflector on standard light units. But the key thing is when in dipped beam mode, these units are BOTH ON with the inner additional LED unit far brighter than the outer unit. Also note the colour temp of these are slightly different than standard (and I find more blue/purple tint) than standard.
When you turn car on, all units swivel. Also the DRLs I seem to think look different to standard but unsure. As it supports the Locator Blue lighting on the DRLs they do seem to be different than standard. Just my thought though. I for sure think this is an option I wouldn't have done without
Old Jun 28, 2015 | 03:24 PM
rustycruiser's Avatar
2015 W205
http://www.al-lighting.com/press/sin...0738c80087a183
Old Jun 28, 2015 | 03:48 PM
jolt8631's Avatar
I agree with all that you say, I was trying to focus on the OP concern about the physical look of the light units.
I also would NOT be without this system - the difference in illumination is substantial around country lanes etc - I guess on straight US freeways etc, you might not notice - but I give it 10/10 for performance.
Old Jun 28, 2015 | 05:06 PM
True101's Avatar
2015 MB Sprinter RV
Thanks jolt8631, Mr5uby, MassC300, Rustycruiser for the great insightful details. Beautiful pics of your C300's. I love these headlights - the 2 LED beams (or whatever they are called) underneath the Arc LED.
a) When driving on low beam, does one beam come on or both come on?
b) I wonder, if the standard LED headlights (with Premium packages) has a single LED beam, and if so to me that single LED beam looks like a larger sized compared to the two LED beams?
c) from RustyCruiser's article, it seems like the Lighting package, also gives stronger tail-light LED's ... that part I couldn't fully comprehend. I previously believed that LED's or Active LEd's, both have same rear lights?
Old Jun 28, 2015 | 06:08 PM
bartola's Avatar
CLA-250, C-300
During daylight they are both on - however notice the stronger high beam (DRL) and dim low beam, at night they reverse.
Old Jun 28, 2015 | 06:48 PM
True101's Avatar
2015 MB Sprinter RV
Bartola, i can't open your link.
Old Jun 29, 2015 | 01:54 PM
l3it3r's Avatar
Veteran: Army
2015 W205 C400 4Matic
I made the mistake of assuming the LEDs would be enough. Coming from a VW GTI with active Xenon headlights which turned and illuminated where you were looking, to the much brighter, but inactive LEDs was a very disappointing experience. My next car will have the lighting package for sure, and I recommend it to anyone buying who might drive at night in ANY setting that maybe confused for dark.
Old Jun 29, 2015 | 02:06 PM
HorshamRebel's Avatar
C Class W204
I've just emailed my dealer to confirm that I have the dynamic LEDs.
I spec'd the car up to have them before all the recent changes, and am now paranoid they have got left off since those changes took place.
Old Jun 29, 2015 | 02:17 PM
True101's Avatar
2015 MB Sprinter RV
this looks really nice (I added the lighting package hearing all the feedback) I particularly like your grille ... where can one buy such a grille?
Old Jun 29, 2015 | 05:18 PM
CJBROWN's Avatar
2011 GLK350
Looks like you can get the 'diamond' grill here: http://www.ebay.com/itm/Diamond-gril...-/161628800366
CLA look or C450AMG.
Old Aug 24, 2015 | 10:38 PM
pointbreak's Avatar
none
His grill doesn't have the gloss black center like the one in the link, he has the all silver grill. I ordered the same one
Old Aug 29, 2015 | 04:37 AM
kjb1's Avatar
c220 amg prem plus / BMW X5 e70
I see no difference in rear lamps with the teo led spec'd cars, looks exactly the same. Base lights look different which is a given.
Old Sep 12, 2015 | 12:49 PM
Capt Slo's Avatar
2019 C43 Sedan and 2020 Volvo V60 CC
I've got experience with both LED light options and I'd definitely recommend the Lighting package. My '15 C300 had them but my salesperson forgot to order them on my '16 C300 (still have LEDs since I've got the Premuim pkg)
Maybe I'm paranoid but I swear the light output from the Lighting pkg is greater than the standard LEDs.
Old Apr 25, 2017 | 11:29 PM
raja777m's Avatar
2014 E350 4M Diamond Silver
Is it only me who wants those small shiny ones to be LED's, in the grill?
Old Apr 26, 2017 | 01:10 PM
drkstvrr's Avatar
2016 C300 / W205
Such a grill actually does exist, and it is hideous IMO.
Old Apr 26, 2017 | 01:21 PM
raja777m's Avatar
https://www.youtube.com/watch?v=aI855d5CvAc
I would love that, only if it can be dimmable and color options, so, I can choose close to the headlight color.
Also, I don't need the whole grill to light up at once, few of them can twinkle at once. I know it is too much, but, it'll look, just my taste
Old Apr 26, 2017 | 06:26 PM
Thlian's Avatar
2018 C350Te Wagon
Led high, has only one led reflect or. The ILS has two and in my opinion looks way sharper. Not to mention dynamic lighting assist 😁
​​​​​​......nah, you just got cornering lights? What a same 😄
Old May 13, 2017 | 01:17 AM
Ali Shahini's Avatar
2017 X5 35i Msport
What's the high beam looking like on the regular LED with no active curve ? I hope its not halogen
Old May 13, 2017 | 03:43 AM
Thlian's Avatar
2018 C350Te Wagon
The one in the middle, if I remember correctly you can also get highbeam assist on those.
Old May 13, 2017 | 05:12 PM
RUNSGR8's Avatar
2017 C300 Coupe - Polar White/Saddle Brown MBTex
Given the clearly visible reflector for the high beam, I'd say yes it is a halogen. However it's the whitest halogen light I've ever seen. It's just as white as the LED low beam so it definitely doesn't look cheap. I have the regular LEDs so I'm speaking from experience.
Old May 14, 2017 | 05:04 PM
richysh's Avatar
c400
its not halogen. Its led
Old Jun 25, 2019 | 03:26 PM
mybill92's Avatar
Mercedes C300 4matic
So I've been trying to get the illuminated star, I replaced the grille with this similar one. I measured it with two different dealerships, turns out the emblem size is around 7 inches on the grille, and the new LED star is 7.5 ish. I'm wondering if you have a link to a good size emblem for this aftermarket grille. HELP! lol
